Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Motor vapor locked. - Troy Bilt Pony 6.5 Hp Rear Tine Tiller
  • 90 Answers
It is a little hard to vapor lock a small Briggs & Stratton single piston engine. To get the carburator that hot the muffler on the tiller may be plugged up, causing the carburator to get too hot. There is a two piece muffler with a screen inside that gets plugged up when you run the tiller on some models. I finally got fed up and got a replacement muffler of a different design to solve the plugging problem. There is also a couple of tubes in the fuel tank with small screens that get plugged up also causing fuel starving to the engine. Also check and make sure the fuel tank cap vent is not plugged up. Good Luck, RAC
Posted on Apr 18, 2009
Having trouble with vapor locking
Vapor lock can be caused by many different things, all coming down to the same root cause: too much heat in the fuel feed lines.
Low fuel pressure can cause the amount of heat needed to vapor lock to be lower than normal, so checking fuel pressure is important. Fuel pump going out feels a lot like vapor lock.
Engine overheat can also cause vapor lock. Clogged fuel filter can cause vapor lock. The fuel line should be routed away from the exhaust system.
Feb 29, 2016 | Cars & Trucks
2005 chevrolet trailblazer troubleshooting
fuel injected car do not get vapor lock,check you fuel pressure,if it is OK (with in spec) pull the vacuum line from fuel pressure regulator if it is wet (gas in it) then you need a regulator as the diaphragm is ruptured ,also bad T.P.S (thrittle position sensor) can cause the same sympton
Aug 15, 2014 | 2005 Chevrolet TrailBlazer
How do i get my 2000 silverado to stop vapor locking
No vapor lock on a fuel injected motor
Basically 1988 on
Need to provide details of the problem
How about discussing the issue with a repair shop?
Jul 06, 2014 | 2000 Chevrolet Silverado
What causes 1995 isuzu vapor lock problems?
Fuel injected engines cannot get vapor lock. First you need to explain how you came to the conclusion if vapor lock. But this is an old post and probably will stay dead.
May 20, 2014 | 1995 Isuzu Pickup
How to fix vapor lock n honda element
Pull the plugs out crank the motor a few times then put them back in
May 05, 2014 | 2003 Honda Civic
I put gas in my 1998 Camry, drove about one block and it stopped. It tries to start when but will not turn over. It's not the battery, energy still on in vehicle, not the starter, no clicking, not the...
IF it was vapor locked it would still turn over just not start. If it was vapor locked you can just loosen the gas cap and it would immediately start. If it is vapor locked you will hear a hissing suction sound while loosing gas cap. Its trying to get air.Quick fix leave gas cap off..Drill a small hole in the center of gas cap. It will let it breath. To fix it right.Buy the filtering charcoal canister. Never put that extra 25 cents in at gas station once gas nozzle clicks. That extra gas goes down the vapor filtering line causing it to clogg up over years.
Aug 10, 2013 | Toyota Cars & Trucks
Vapor lock 454 chevy p30 motorhome
Its possible if you have a carb instead of fuel injection.
The engine would stall and have to sit for a while to cool off before restarting. The carb would in effect run out of gas.
Jul 23, 2013 | Cars & Trucks
Possible Vapor Lock Fix
There has been no fuel vapor lock in almost
30 years,does not happen with fuel injection
Why not have a shop diagnose & repair the issue
Jul 17, 2013 | 1993 Ford Tempo
How do you fix vapor lock on a 1996 buick road master
Pull the spark plugs and turn the motor over a few times. On these cars they do not "vapor lock", instead you will need to replace the intake gaskets as they tend to mushroom and cause the vehicle to hydro-lock (usually in the #3-#5 cylinders). Also look forward to drilling out the #12 intake bolt as that is usually rusted into the block. Good luck
Aug 09, 2011 | Buick Roadmaster Cars & Trucks
The engine sputters and dies when it heats up. Is this Vapor lock? On cold start it works great and idles just fine but as it heats, the engine starts choking and soon dies out. If this is vapor lock, how...
sounds like the reason it starts and idles fine at start up is your choke is functioning... as your vehicle warms up.. the choke starts to kick off... Inspect your throttle body and idle control motor.
Aug 05, 2010 | 1986 Ford Bronco II
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
210 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
