Question about KitchenAid KGSI901PBS Gas Kitchen Range
Kitchenaid KGRA806 Oven Won't Ignite
I have a kitchenaid KGRA806. When I turn the oven on I hear the fan spin up and then I hear two clicks which sounds like an igniter coming from the bottom of the oven. But neither the top igniter or bottom igniter in the oven makes a spark. What needs to be replaced and how do I replace it? Thanks.
  • Anonymous Mar 31, 2009
    I have the same problem but it is only with the oven not the burners... we have had a repairman come in twice and both said it was the mainboard and replaced it, but it only worked for a short while each time.
  • 1Meg Apr 10, 2009
    I have exactly the same problem and I do not have a solution yet. ugh!
4 Suggested Answers
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
  • 57 Answers
SOURCE: Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Posted on Sep 22, 2009
SOURCE: kitchenaid gas range model KGRS807S - oven starts then stops
earl am16 error
Posted on Apr 16, 2010
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
I purchased a used Kitchenaid Superba oven model KEBC107KSS03...I was so excited! BUT, the display works and the oven will not heat...I read that if the self cleaning buttons are pushed/used the oven
Feel for you you expect it to work I work on these everyday 95% of the problems stem from the install not enough room left for proper air circulation when you turn on the unit and start a bake cycle do you hear a click this would be the heat relay closing also does the cooling fan come on you should feel air coming out below the door if so good without being there to test I would guess either an open TOD from self cleaning or improper voltage
Dec 21, 2014 | KitchenAid Kitchen Ranges
My KCMS1555SSS-2 will run only if I partially depress the door open button.
<- That is likely a loose, misaligned, or broken door switch or door switch mount.
You can find the support documents for this model here, including the parts list, which includes helpful exploded views.
Also see these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can order Kitchenaid parts from the Pros here.
Jan 05, 2014 | KitchenAid KCMS1555SSS Microwave Oven
Electronic control board
If you are hearing a clicking sound, that would be the igniter trying to light the gas, however you said elements not heating up which says it's electric... hmmm. If it's electric, try the broiler and see if the element comes on. It's pretty easy to troubleshoot by process of elimination. By all means do not try and repair it yourself unless you are qualified working with electrical.
Jun 14, 2017 | KitchenAid Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
GE Profile JCKP18BW-1 Built-in Oven/Convection fan clicking
how to reset electronic
GE PROFILE jckp18bw
Thanks
Dec 27, 2012 | Ovens
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
I hear the oven igniter clicking but the oven does not come on
Spark board fails...gas valve coils open.. spark probe failure.. among other possibilities.
I have changed all three in the past and the spark probe still does not light. Never found out why.
Feb 07, 2012 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGSI901PBS Gas Kitchen Range Logo
698 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
