Question about Posiflex JIVA 8000 Touch Terminal Network Terminal
I can not set up touch screen - Posiflex JIVA 8000 Touch Terminal Network Terminal
  • 82 Answers
Make sure you are using the right driver, posiflex use two different type of touchscreen, elo and fujitsu.
Posted on Aug 27, 2010
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
How to reset ipod
Fully charge your iPod touch to prevent draining your battery during the factory reset.
Touch "Settings" on the device's Home screen.
Select "General" from the "Settings" menu.
Choose "Reset."
Select "Erase All Content and Settings." A confirmation window pops up on the bottom of the screen.
Touch the red confirmation button on the bottom of the screen.
hope this helps
Oct 14, 2012 | Apple iPod touch Second Gen (8 GB,...
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
How do i get bass from my iva-d310
To get to the bass settings touch [SETUP] on the source main screen and on the next screen touch [i-Personalize]. Touch [>>] of BASS ENGINE. The screen will change to the Bass Engine setting screen. Touch left or right arrow or [>>] of the desired Bass Engine setting item (i.e. Bass Max EQ, Bass Focus, etc). Touch arrows or the adjusted screen of the selected setting item, and change the setting. When setting is complete, storing in memory is recommended. Touch [RETURN] when finished.
For more information go to manual, page 37 and 38: http://www.fixya.com/support/p199196-alpine_iva_d310_car_dvd_player/manual-2142
Feb 23, 2011 | Alpine IVA-D310 Car DVD Player
How you control your bass
Touch [SETUP] on the source main screen and on the next screen touch [i-Personalize]. Touch [>>] of BASS ENGINE. The screen will change to the Bass Engine setting screen. Touch left or right arrow or [>>] of the desired Bass Engine setting item (i.e. Bass Max EQ, Bass Focus, etc). Touch arrows or the adjusted screen of the selected setting item, and change the setting. When setting is complete, storing in memory is recommended. Touch [RETURN] when finished.
Feb 08, 2011 | Alpine IVA-D310 Car DVD Player
Touch screen is not functioning
align screen via.settings---screen!
Mar 09, 2010 | HTC Touch Dual Slider Smartphone
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
Jun 11, 2009 | Konica Minolta Office Equipment & Supplies
Touch screen not working
   That's the main problem with most of the touch screen.
In case, if it's not working, you need to replace that ( In case, you are sure you haven't played with settings )...
Reset the phone - Factory settings.
In case if the issue would be there, confirmed faulty touch screen. If under warranty, get that exchanged unless buy a new touch screen.
Go for original touch screen setting unless might cause this issue again.
Thanks for using Fixya.
Apr 23, 2009 | ASUS P527 Smartphone
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Posiflex JIVA 8000 Touch Terminal  Network Terminal Logo
335 people viewed this question
Top Posiflex Computers & Internet Experts
Jason Morris
Will Halftowaite
Are you a Posiflex Computer and Internet Expert? Answer questions, earn points and help others
