Question about Texas Instruments TI-83 Plus Calculator
The ti 83's screen turns on with a line across the screen.
The screen turns on with a line across, and then it slowly fades out. I have tried to use the one battery removeal method, but it did not help. Please, is there any way i can get my calculator back to the home screen? Thank you in advance!
  • Anonymous Mar 14, 2009
    i have a similar problem. when i turn on my claculator a black line appears and fades within seconds. I have tried to replace the battries (including backup) but there is no difference. Can anyone help with this?
  • Anonymous Apr 01, 2009
    same problem line appears than in 2 seconds dissapears and when i turn it on again it happens again?
  • 32 Answers
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Posted on Sep 16, 2008
SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
how do i find the anilog on my calculator i have a texas instrument ti-30
Posted on Oct 15, 2008
  • 8 Answers
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
Posted on May 08, 2009
SOURCE: TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Posted on Aug 30, 2009
  • 7993 Answers
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
  1. press [2nd] key and release it.
  2. Press the Up arrow and HOLD pressure.
  3. Keep pressing the arrow key until screen is dark enough.
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Posted on Jan 21, 2010
I have an old TI-83 and there are vertical lines across the screen which have dead pixels, I assume. Can this be repaired or do I have to buy a new one.
While someone skilled in electronics may be able to fix it with enough time, the cost in time and labor would far outweigh the cost of a new calculator.
Feb 28, 2011 | Texas Instruments TI-83 Plus Calculator
How do i turn on my TI-83 when i already put batteries inside? at first the numbers would fade away but now it dosent want to even turn on.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 18, 2010 | Texas Instruments TI-83 Plus Calculator
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
There is a Fading strip of white Running across my screen
try resetting your phone factory setting it will help.
Jul 02, 2009 | Nokia E63 Cell Phone
On TI-83 How do you change the batteries?
Try pressing the 2nd key and then holding down the up arrow key first.  This changes the contrast on the screen- makes it darker.  Pressing the 2nd key and then holding down the down arrow key will make the screen lighter
Feb 02, 2009 | Texas Instruments TI-83 Plus Calculator
Help
i had the same problem, so i took all of the batteries out (including the back-up battery) and then i hit the on button a few times. i then proceeded to reinstall all of the batteries, AAA first, and then the back-up battery after the calculator was already on. it works great now.
Jul 09, 2008 | Texas Instruments TI-83 Plus Calculator
My TI-83 is all messed up
Sorry to hear that you are having problems with your TI-83. The TI-83 is a discontinued calculator, so I really don't think that it can be repaired/replaced.
See TI's website below for more information:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71440&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGEE602C53EA628B70E47DD2DD6878A5ABD632AD5834DE8ADC18D66ABBC9F888CBF7FB517A0B05B0984776B37370A28975B2
Feb 24, 2008 | Texas Instruments TI-83 Plus Calculator
Line across the screen
If it's just a single line then it sounds like that the screen is not connected probably or is shot...
if it's more of a "flurry" or snow... then you can connect to another unit via the I/O cable or usb if your model has it, and use the "send OS" command to start from scratch and lose all data but have a working calculator.
Feb 07, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 LCD Screen Problem
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Aug 14, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
639 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
