Question about Gateway M305CRV Notebook
Memory problem I have a Compaq Presario R4000. I purchased it a few years ago with only 256k memory on the mother board. I figured I could add more later. I then purchased a second 256k module. I installed it and all was fine. I have now decided I need alot more. I purchased a 1GB PC2700 DDR333 from Memory Ten. I installed the module in place of the removable 256k I had The laptop just sits with a blank screen. Compaq says this is the right memory and has no idea why it doesn't work. They had me upgrade the bios but no luck. When I put the 256k back in all is fine again. The info can find is I can add up to 2GB in any combination. Does the largest memory module need to be installed in the slot that is not accessable to me???? THANKS
  • 35 Answers
The memory upgrade FAQ for your PC is located HERE. It says that the maximum amount of memory is 1GB, and from the components list HERE, the largest it can handle with one stick would be 512 of PC2100 memory.
Posted on Mar 11, 2009
  • 6,784 Answers
You may have purchased a memory stick that requires more speed than your memory block can give. the speed for this lap top should be around 455-500 MHz on the memory block. if the memory stick requires more than that, its not going to work.
Compaq R4000 laptop monitor
Sorry, no. There is an on-board GPU that drives the display on the mother board and without it, there is no display.
Oct 23, 2011 | HP LCD Display for Compaq Presario R4000
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
I have a compaq r4000 cto. I just replaced the system board with a used board. When I first started it up I got a black screen and three beeps which after a few tries became a black screen and four...
It's unlikely that you have 2 or more defective memory modules. Remove all cards such as video, modem, etc. Also disconnect all drives (hard drive, CD, DVD). Try booting with one memory module at a time. If still a no go then I would suspect the motherboard.
Feb 20, 2011 | HP Compaq Presario R4000 Notebook
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
Screen won't display
It's quite possible that the mother board (your main circuit board) and/or display adapter was damaged. Your only recourse now, most likely, is to contact HP. Good luck!
Apr 18, 2009 | HP Compaq Presario R4000 Notebook
Memory upgrade
THIS IS THE ONLY ONE YOU WILL SEE AS THE OTHER IS MOUNTED ON MOTHER BOARD BUILT IN THE ONE YOU SEE IS THE ONLY SLOT AVAILABLE FOR UP GRADE
Jan 24, 2008 | HP Compaq Presario R4000 Notebook
Gateway M305CRV Notebook Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
