Spooler Sub System App stopped working and was closed All 3 of my printers are inoperable!! How do I reopen Spooler System?
  • hugh_william Mar 11, 2009
    I am running Vista Home Premium on Dell DIMENSION E520.
    I have already been in touch with Microsoft, who suggest re-installing printers - BUT installation will not proceed because Spooler closed. Also received advice from Dell to use "service.msc" and re-set 'Print Spooler'. Appears to work but no difference in printer display on 'control' - blank screen. Occasionally have seen the printer list, showing HP1020 Laser on line, but when calling for a print in Word (Office 2007) nothing happens!!
    Just this evening, technician from Dell (Phillipines) has spent one hour operating my machine remotely without resolving the problem. The Spooler just does not actually re-set to open, although it says it is open.
    Thanks for your interest - this really is a tricky one!
    Scholar:
  • 164 Answers
Have you looked at this Microsoft KB article;
support.microsoft.com/kb/324757
There are few registry edits which if you follow the KB's mentioned should fix your problem.
I hope this helps;
Thanks.
Posted on Mar 11, 2009
  • 10,515 Answers
Start Regedit, go to Computer\HKEY_USERS\S-1-5-18\Printers, and create a
new key named 'Connections' (right-click when 'Printers' is open and
choose 'new key'. That will solve it. It's only an annoyance, and
doesn't appear to affect anything. I have an HP printer and had the same
issue.
  • 583 Answers
Dissconnect and recconnect all the printers and restart the system initially and check first.
  • 13,433 Answers
Hold down the windows key press r, type services.msc into the run menu.
In services. Find spooler and right click on it and select Start-
  • Ekse Mar 11, 2009
    1. Press the windows key, then R. Or open the start menu and select run.
    2. Type in the run menu: services.msc
    3. in services msc find the printer spooler, right click and start.
    if you receive a error message let me know.
    Best solution is most likely to sort this out over remote support. Let me know if this doesn't fix the problem so me and you could troubleshoot it over remote support. reposting will get you another expert.
  • Ekse Mar 11, 2009
    Have a look at my solution, Thanks
  • 408 Answers
What OS are you running, please do not rate this post, I am just asking for some clarification.
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
Tip
Printer Spoiler problem
<p><br />If the Print Spooler service fails when printing or when Windows starts or it can not be restarted, the usual reason is that one or more printer drivers is defective. The simplest way to resolve this is to remove all the drivers and reinstall them again.<br /> <p><br />If the Print Spooler service is not running, the Printers and Faxes folder will be empty and you can not use it to remove (or add) printers or printer drivers. <br /> <p><br /><b>Resolution:</b><br /> <p> <br /> <p><b>Windows XP:</b><br /> <br /> <p>If the Print Spooler service is operational:<br /> <p>1.<span> </span><span>Open the <b>Printers and Faxes</b> folder, Start-&gt;Printers and Faxes.</span><br /> <p>2.<span> </span><span>Delete all of the <span>printers</span></span> <br /> <p>3.<span> </span><span>Click <b>File</b>, Server Properties</span> <br /> <p>4.<span> </span><span>Select the <b>Drivers</b> tab</span> <br /> <p>5.<span> </span><span>For each entry:</span> <br /> <p>a.<span> </span><span>Select the entry</span> <br /> <p>b.<span> </span><span>Click Remove</span> <br /> <p>If the Print Spooler service is not operational:<br /> <p>6.<span> </span><span>Open regedit Start-&gt;Run and type regedit.</span> <br /> <p>7.<span> </span><span>navigate to <b>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers</b></span> <span>Under this key, there will be the keys Version-2 and Version-3 (one or the other of these may be absent - not a problem) the sub-keys under these contain the printer driver configuration information. Delete all the sub-keys inside Version-2 and Version-3, but <i>not</i> these keys themselves</span><br /> <p>8.<span> </span><span>Open a Command Prompt window</span> <br /> <p>9.<span> </span><span>Type the commands<br /> <span><b>net stop spooler</b></span><i><br /> </i><span><b>net start spooler</b></span></span> <br /> <p>10.<span> </span><span>Open Windows Explorer</span> <br /> <p>11.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\printers\</b> and delete any files there. By default, this is where the <span>print spooler</span> stores print files.</span> <br /> <p>12.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\drivers\w32x86</b>. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem) delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside w32x86, there may be other folders with names starting with "hewlett_packard", "hphp" (ex. for HP printers) or something else; delete these folders also</span><br /> <p><span>13. </span><span>Restart the <span>print spooler</span> (see steps 8 and 9 above)</span><span> </span><br /> <p><b>Windows 7:</b><br /> <ol> <li> Go to <b>services.msc</b> -&gt; stop the printer spooler service. <li> Get into windows /system32/spool. <li> Find folder named printer and delete the contents of it. <li> Restart the printer spooler service, check for printing. <li> Restart the computer and check it again.</li></ol> <p><span> </span>OR<br /> <p>cmd<span> </span>-- &gt; net stop spooler<br /> <p>del /q /f /s "%systemroot%\System32\Spool\PRINTERS \*.*"<br /> <p>net start spooler
on Mar 10, 2011 | Office Equipment & Supplies
Microsoft said spooler subsystem app not working
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer with your spooler services enable now.
YBC (/\)
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
New z2400 will not print a page (worked fine for the last couple of days), pop ups state in process of printing 2 pages, printer is diconnected and power off, but unable to delete printing process on the...
This may help you
How to force delete print jobs Fortunately, there is a way to delete the hung print job without having to save all your work, close all your applications, and restart your computer. Here's how (note that this is intended for Windows XP systems, but a similar approach works on other systems - if this doesn't work for you reply below with your Operating System and version):
  • Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  • Browse to your windows\system32\spool\PRINTERS\ folder
  • You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  • Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  • Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Voila :) You should see that annoying hung print job finally disappear completely and you should now be able to resume printing without having to restart your computer.
From http://community.contractwebdevelopment.com/how-delete-or-cancel-hung-print-jobs-windows
Dec 12, 2008 | Lexmark Office Equipment & Supplies
How to fix 'print spooler'
  1. open regedit (e.g. click Start, key regedit and press Enter)
  2. navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
under this key, there will be the keys Version-2 and Version-3 (one or the other of these may be absent - not a problem)
delete all the sub-keys inside Version-2 and Version-3, but not these keys themselves
The Microsoft Knowledgebase article at http://support.microsoft.com/default.aspx?scid=kb;en-us;312052 lists some other registry entries to delete, but this is not usually necessary.
  1. open a Command Prompt window
  2. key the commands
    net stop spooler
    net start spooler
  3. open Windows Explorer
  4. navigate to %systemroot%\system32\spool\printers\ and delete any files there. By default, this is where the print spooler stores print files.
  5. navigate to %systemroot%\system32\spool\drivers\w32x86 (%systemroot% is usually Windows, but it might be winnt or something else; this is set when the OS is installed).
  6. inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem)
    inside w32x86, there may be other folders with names starting with "hewlett_packard", "hphp" or something else; delete these folders also
  7. restart the print spooler (see steps 8 and 9 above)
Aug 08, 2008 | Office Equipment & Supplies
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
DP-2330 on Vista
To start your spool service type spoolsv.exe in the run box.
Apr 10, 2008 | Panasonic Workio DP-2330 Printer
HP print spooler problem and error 1068. Want my printer back!!!
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
