Hi there: I suggest to check this on 2000 Subaru Outback Wagon Car Radio Stereo Wiring Diagram:
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Red Car Radio Ground Wire: Black Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Brown/White Left Front Speaker Negative Wire (-): Green/Black Right Front Speaker Positive Wire (+): Red/Yellow Right Front Speaker Negative Wire (-): White/Black Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Red Left Rear Speaker Negative Wire (-): Red/Green Right Rear Speaker Positive Wire (+): Blue/Green Right Rear Speaker Negative Wire (-): Red
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Check this information about 2005 Subaru Outback Wagon Car Stereo Wire Guide:
The 2005 Subaru Outback Wagon radio wire color information above is updated as it is submitted by the Modified Life community.
Hope helps (remeber to rated ans leave an testimoanial about this free answer).
1996 Subaru Outback Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Green
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Illumination Wire: Red
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
2004 Subaru Outback Wagon Radio Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: Blue/Yellow Radio Accessory Switched 12v+ Wire: Yellow/Red Radio Ground Wire: Black Radio Illumination Wire: Green Stereo Dimmer Wire: N/A Stereo Antenna Trigger: N/A Stereo Amp Trigger Wire: N/A Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Brown/White Left Front Speaker Negative Wire (-): Green/Black Right Front Speaker Positive Wire (+): Red/Yellow Right Front Speaker Negative Wire (-): White/Black Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Red Left Rear Speaker Negative Wire (-): Red/Green Right Rear Speaker Positive Wire (+): Blue/Green Right Rear Speaker Negative Wire (-): Red
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power. Car Radio Ground Wire: Black/White Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Pink Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
