Question about Behringer Audio Players & Recorders
Just starting . how to use and understand
Just starting . want to know how to use and understand behringer mic amp 802
Just need simple understanding what each thing is for so i can get my head around it, Gail
  • gail_roberts Mar 11, 2009
    dante777
    Hi, Thanks I do have a manual, and you may think me thick, but I honestly need to understand what each knob is for and the manual presumes you know, I will eventually figure it out.
    I am working better with my recording program, it seems to have taken forever for me, but I sure am not giving up no matter how long it takes. I am a songwriter trying to get my songs ready to send to the Guild for songwriters and composers in the UK.
    Thanks Gail
    President:
  • 623 Answers
Why don't you take a look at the manual?
If you don't have it, you can find it here.
Is that what you were looking for or do you need explanations for things like EQ, Pan, Frequency, etc.?
If so, let me know and I'm happy to help.
In general: I worked with Behringer equipment a lot and always liked it. No fuzz, solid built and good sound.
Posted on Mar 11, 2009
I got behringer 802 audio mixer and a mic..what else do i need to start singing..
Please verify if your computer has a sound card. You will need a provision on your computer for audio input. Let me know.
Dec 26, 2014 | Behringer XENYX 802 Mixer
My aim is to be able to drive a sine wave generator directly from vocals through a microphone. The set up I have planned so far goes - microphone (Behringer B-1) - Power supply (Behringer PS400) - min
  1. Yes, you need the PS400 with the B-1. Alternatively, you can connect the mic to a mixer with built-in phantom power.
  2. The PS400 shouldn't go directly to to the TA2020 because the power supply is providing a mic-level signal and the amp is looking for a line-level signal. Either add a mic preamp after the power supply, or if a mixer is used, that output can be fed to the amp.
  3. Cabling will depend on what you ultimately choose to do. But, you'll at least need a mic cable to go from the B-1 to the power supply or a mixer.
Oct 30, 2014 | Behringer b-1 single-diaphragm studio...
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
Please can you tell me the difference?
The microphone preamps are different. The Xenyx has lower noise mic preamps.
Nov 04, 2013 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I cant get sound from fx send to my computer
Open the volume mixer on the pc and make sure the mic port is on. When you find it, click on the "advance" tab and there will be a check box allowing you to add 4db to the volume of the mic. Also, make sure it is plugged into the line in or mic input on pc.
Mar 16, 2013 | Behringer XENYX 802 Mixer
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I have purchased a Behringer B1 Condenser Microphone. I do not understand how to power it. What are the appliances and steps that I need to get started?
You need to use a phantom power supply. 48V in your case. the Behringer ps400 is your best bet its only 20 bucks from amazon..
Oct 31, 2010 | Behringer B-1 Professional Microphone
My microphone doesn't do it right.
Some of the Podcast mics are condenser mics and MUST be used with a preamp or DEVICE that supplies PHANTOM power to the mic.
You computer DOESN"T supply Phantom power.
Read up on Phantom power in Google to understand it.
Apr 03, 2009 | Behringer XM8500 Professional Microphone
Shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Jan 07, 2009 | Shure SM58 Professional Microphone
61 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
