Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Too hard to crank, the rope is wrond too tight.
  • roxie_munn Mar 11, 2009
    My husband drained the gas & the oil 3 or 4 times. It will crank once then it's wound too tight to pull the cord to crank a second time.
  • 40 Answers
You may want to check the oil level, some units can leak gas through the carb and into the cylinder. thus raising your oil level and making it hard to turn over.
Posted on Mar 11, 2009
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
How do I start a husqvarna chainsaw that builds up pressure so tight I can't crank it with a rope
Take out your spark plug and clear out the extra fuel. Needs a carb rebuild.
Oct 04, 2014 | Husqvarna Garden
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
You hand winde it in a CCW direction BEFORE installing the rope all the way until you feel significant resistance. (It really helps if there are 4 hands doing this). You then align the pulley knot hole with the rope guide but letting it rotate CW until it just lines up. Have that 2nd pair of hands GRASP the pulley tightly. Then pass your rope throught the rope guide and into the knot hole of the pulley. Tie 1 small tight knot and PULL hard on the rope to seat the knot in the hole. Let go of the pulley and the rope will spring wind into the starter recoil assembly. Sounds easy.. but can be quite tedious.
See this link for pictures.
(Ryobi) but the concept is the same.
Thanks for choosing FixYa,
Jul 20, 2011 | Garden
Crank rope extreemly hard to pull.
Take the spark plug out to see if there is fuel in the cylinder...drain it out if there is lubricant in the cylinder.....pull the rope a few times and then go back to normal start procedures.
Feb 07, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
May 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
1992 Honda Accord lx
Sound like you have the typical "frozen" crank bolt. To remove it, it's counter clockwise. What you do to remove it when it's frozen, pull #1 spark plug out, rotate crank so #1 piston is at the bottom of the cylinder. Now take a long piece of rope and stuff it into the spark plug hole as much as you can. Use a screwdriver to keep stuffing rope into cylinder. The rope is now a piston stop. When turning the crank counter clockwise to remove it, you'll feel the crank stop. Now you can crank on the wrench to break the bolt loose. I use a long 1/2" drive breaker bar, long 1/2" extension, and a jack stand to support the extension and with a jack handle over the breaker bar, pull hard and you'll hear a loud pop. At this point the bolt will break loose for you. Don't worry you will not break the crank bolt doing this. After the bolt breaks loose, rotate the crank clockwise again just enough the remove the rope.
Aug 10, 2008 | 1992 Honda Accord
Crankshaft bolt removal on 94 accord
Ok, what you do is remove #1 spark plug. Position the piston in that cylinder so it's at the bottom. Get a long piece of rope and stuff as much of it into the spark plug hole as you can. This is now your piston stop. Now place your socket onto the crank pulley bolt and remove it. You may need a long breaker bar or slip a floor jack handle over what you're using and loosen the bolt. If the piston rotates all the way around, you'll have to stuff more rope in the cylinder. Use a long screwdriver to cram it in there. You'll hear a loud pop and that's when the bolt has broken loose. Before you take the bolt out, rotate the engine the other way to get the rope back out. For some reason the Honda crank bolts are on there really tight.
Jul 22, 2008 | 1994 Honda Accord
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
124 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
