Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite laptop does not power up. AC/DC adapter is.
Cool, usually warm, do these go bad?
  • Timothy Bright May 11, 2010
    Are you talking about your computer being cooler then normal?
    Sniper:
  • 65 Answers
The answer to your question is yes. It doesn't matter if you are talking about your laptop or the AC Adapter. They do go bad. If you are talking about the ac adapter you probably can take it down to a radioshack and have it tested.
Posted on Mar 21, 2009
  • Dusty Colvard
    Dusty Colvard Mar 21, 2009
    It can also be a bad battery if the computer will not turn on
Won't turn power on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L555 AC Adapter 90Watt 19V 4.74A
Jan 05, 2013 | Lifetime Toshiba Satellite L555S7008...
L655 Satellite won't start up.
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
Toshiba Satellite L505DGS6000 Laptop will not turn on
Replacement Toshiba Satellite L505D AC Adapter 120Watt 19V 6.3A
Oct 28, 2012 | Toshiba Satellite L505DGS6000 Notebook
A665 Toshiba satellite when i switched on no dispaly after a while it's turn off the fan is noisy
Please remove the battery and ac power adapter. hold power on button for 1-2 minutes. Then try to power on laptop with ac power adapter without battery. check the display of laptop.
If not check the dc voltage of the ac adapter. is it the same voltage as written on the ac power adpater. if not same please try with another adapter.
If not remove the hard disk and ram. clean the fan,ram. Reinsert ram and power on with ac adapter. check the display.
Please check with external display if laptop is turned on but no display.
Jul 01, 2011 | Toshiba Satellite A665-S6086 Laptop
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
AC/DC adapter
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
