Question about Microsoft Computers & Internet
Pps como convertir u n archiva Power Point en PPS, asi comprimirlo y enviarlo via E-mail, la presentacion tiene un peso de 2.13 MB
    Champion:
  • Microsoft Expert
  • 405 Answers
For powerpoint files use item below
This article http://www.powerpoint.repairtoolboxx.com/es will help you
Posted on Aug 06, 2013
SOURCE: Microsoft Power Point
Not sure, try downloading Power Point Viewer instead:
http://www.microsoft.com/downloads/details.aspx?FamilyID=428d5727-43ab-4f24-90b7-a94784af71a4&displaylang=en
Posted on Nov 09, 2007
ziraffa
  • 827 Answers
SOURCE: opening pps messages
Hi nati662992,
pps files are Microsoft PowerPoint slideshows.
Because Powerpoint is part of the Microsoft Office package, you would think that you would have to purchase Microsoft Office to view .pps files. This is not so. You can download the free PowerPoint viewer from here:
http://www.download.com/PowerPoint-Viewer-2007/3000-18483_4-10742145.html
Install that and reboot.
Then open the email again and it will automatically open with Powerpoint Viewer. Or it will ask you what program you want to open it with, and you click the PowerPoint Viewer .exe icon, and tick the 'Always open with this Program?' box.
Good Luck and Season's Greetings to you!
Chris (ziraffa)
Posted on Dec 22, 2008
  • 6 Answers
SOURCE: I want to save photos from a pps file but don't know how to do it
Good afternoon. Open the pps file and right click on the picture. You will have an option to save as picture. Once selected, name the file and the file location. Also you will have an option to save as a jpp file.
Posted on Feb 25, 2009
  • 130 Answers
SOURCE: *.pps is not a valid Win32 application
Right click on the file and go to open with then select the Powerpoint Viewer 2007 and check the box making it the default.
Posted on Jun 13, 2009
bschilz
  • 2049 Answers
SOURCE: Problems viewing pps files.
Right click on a pps file you have, choose Properties and check Opens With to see that Power Point Viewer is the default program to open it with.If it's not PPT Viewer use the change button to change the default.
Posted on Aug 10, 2009
Diagrama de encendido ford ranger 2002 3.0 v6 2wd
losiento amigo pere esta marca de coche no existe en espana ,algunos si por el hydroelectra pere yo tienes ninguno experiancia con uno de gasolina ,esta tonto jiddy pinthando mejor pregunta con una chaputhero de mechanico local .Possiblymente utilithado el ECU mas chip e transponder de la vehcula donante
Jul 25, 2013 | Cars & Trucks
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Enciende y aparece el logo de la bateria y luego se apaga , y por mas que lo haga cargas mas horas sigue igual . Por favor no se sin ayudar
Si cuando te aparece el logo de la bateria, esta tiene poca carga a pesar de haberla cargado durante horas, entonces podria ser:
1) Un da?o en el cargador (en este caso igual no funcionaria aunque tuvieras la laptop conectada directamente al tomacorriente). 2) Un da?o de la bateria (la bateria no esta tomando la carga). 3) Un da?o en la fuente de poder.
Tambien te recomiendo revisar que los contactos esten limpios: 1) Donde la bateria tiene partes metalicas que hacen contacto con otras partes metalicas de la PC. 2) Donde hacen contacto las partes metalicas del cargador con las partes metalicas de la laptop.
Asi podras saber si tienes que cambiar el cargador, la bateria o si tienes que llevar la PC a un taller a que le revisen la fuente.
Oct 19, 2010 | Computers & Internet
Tengo un nintendo DSi negro "consola" y el Browser, osea el icono de la Web no aparece entonces como puedo accesar a internet? Nota: La senal de internet si la agarra porque si tomo una foto me permite...
el canal de internet al igual que el flipnote studio se descargan de forma gratuita a traves del canal "tienda nintendo dsi" o bueno almenos a mi me aparece asi
Sep 11, 2010 | Nintendo DSi Black Console
Como encender wirless
algunas tienen el boton enfrente de la compu o a los costados otras tienes que precionar fn esta en la parte inferior de el tecleado solo esta asi fn sin soltarlo preciona la tecla que tiene una como antena ointada esta en la linea de los botones de arriba empesando con fi el que tenga el dibujo de la antena si tienes mas dudad tony30_2_1@yahoo.com
Mar 26, 2010 | Gateway 4026GZ Notebook
HOLA NECESITO EL TIEMPO DE UNA ISUZU RODEO 1995 4 CILINDROS. CUANDO LA PRENDO TIENE UN FALLO QUE HACE COMO UNA EXPLOSIONES EN EL MOTOR, Y ASI CORRE. SI TIENEN LA SOLUCION SE LOS VOY A AGRADECER...
Tengo una isuzu rodeo 1995, empezo a encender la luz de check engine y se me apagaba y no queria encender...luego encendio, a veces hace como si no tuviera gasolina pero a veces enciende y se apaga, la utilizo asi pero cuando enciende el check engine se queda sin corriente y se apaga por completo, le lleve a hacerle un chequeo y ni el tecnico encontro nada, me pueden ayudar con ese problema?
Nov 29, 2009 | 1993 Isuzu Amigo
Mitsubishi ws-48311
DEPENDE DEL TAMANO O SI LA QIERES NUEVA ODE SEGUNDA MANDO EN REALIDAD SE VA AVER IGUAL TIENE 3 HOJAS LA PRIMERA SE LLAMA PROTECTOR SCREEN ,LA SEGUNDA SE LLAMA LENTICULAR; Y LA TERCERA ES EL LENTE BUSCALA EN VANCE BALDWIN.COM O MATS ELECTRONICS DEPENDE DONDE VIVAS USADAS LAS TRES VALEN COMO 150 O 200 NUEVAS COMO 500 LAS TRES
Oct 20, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Sonido en la rueda derecha
Si el sonido se verifica como apreta los frenos, y es como un rascar de metal, entonces tiene que sostituir las pastillas de freno.
Si el sonido esta todo el tiempo, quando se tuerce el volante, y es como un rascar o como un sibilo, tiene que veer con la parte que en ingles se llaman wheel bearings.
Oct 02, 2008 | Mazda 626 Cars & Trucks
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Apr 06, 2008 | Sony Ericsson K750i Cellular Phone
Computers & Internet Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
