Question about Mitsubishi Televison & Video
Mitsubishi television model WS65611 Serial 113678. Television does not response to remote. Can manually turn on but no other buttons work. Picture and sound are good.
  • 111 Answers
Buy an infared card at local electronics store. Press remote and point at card, should glow orangey. If not then remote is bad. If it glows then reset remote, lastly open up remote and clean the finger pad on the back with alcohol gently, really gently. Look for soda , coffee etc. Good luck , be safe..
Posted on Mar 11, 2009
My tv doesn't show the entire picture. I'm sure it has to be the settings but I don't know what to change it's a Mitsubishi and directv is my provider
  1. Press MENU on your remote control, select Settings in the heading, then select Television.
  2. Select Screen Aspect ratio and high definition, press OK.
  3. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  4. Press OK.
Sep 28, 2016 | Mitsubishi Televison & Video
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
When I turn on my WS65611 rear projector TV the picture comes on perfect but after a minute it starts going static then the picture will come back on then it goes stactic. This continues for as long as the...
A few things you could and should try, try something on a different input if you are using the coax connection just to know if problem exists that way, could be a bad tuner but that can be got around, also if on all inputs the set does have a hard reset that requires the Mitsubishi remote and a four digit code to enter the hidden option menu.
check the other inputs first please and let me know.
Aug 27, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS65611 no remote function & panel buttons not working
This TV is known for the buttons going bad. You can remove the speaker grille to gain access to the wires for the panel. You may have to pull off the font access panel to get to the connector. There will be two of them, one for the input, other for the control panel buttons. If the buttons are bad, unhooking them will make the TV work fine with remote. I believe the connector is labeled ZR and is not the one with the thicker black wires (shieled video wires). Unhooking is my fix for this problem as replacing the buttons seems to be only a temporary fix.
Dec 04, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Locked out of older Mitsubishi VS4503R. Need owners manual/help!
If you are locked out of the inputs, you need a original Mits remote. Push QV and the 9 button simultaneously to unlock temporarily. Some models its the SQV button and 9. This will let you get in to change the code. You can also get a simmilar issues with the active AV network turned on, it will lock it to a set input (ie input 1). Try going into the menu and turning the av network off.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Television Model # WD-52627, Serial # 107108 - TV Not Responsive
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Aug 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Volume and mute buttons
I found the manual you need: http://download.jazel.net/misc/filecache/bc/bc9ff1b4e9d65cfcf99b8cea4b75180f_1104-V17++.pdf
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
