Question about GE Refrigerators
FRESH FOOD SIDE NOT COOLING - GE Refrigerators
  • GE Master
  • 3,361 Answers
Open the air vents and make sure the freezer fan is working and no ice buildup on the back freezer wall.
Posted on Mar 11, 2009
HVACRH20
  • 237 Answers
SOURCE: Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Posted on Nov 10, 2006
Sea Breeze
  • 4654 Answers
SOURCE: Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
Posted on May 18, 2009
SOURCE: Fresh food compartment not cooling. Freezer seems to be working
Evaporator coils iced up- either bad bi-metal thermostat,heater or board.Check resistance on thermostat/heating element.If reading resistance try and jump board into defrost mode by jumper wire from l-1 to defrost lead.
Posted on Sep 16, 2009
heatman101
  • 43501 Answers
SOURCE: ge profile side by side model #pss27nsw. fresh
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
Another problem that can come up is that the defrost coil it's self can fail.... this is less common a problem, but it can happen. If you have an Ohm meter it is real easy to check the coil. If it has resistance then it is good.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
What do I do,my Samsung freezer is working but not the refrigerator which is not cooling,how much should the setting be on both
The normal setting for freezer and fresh food side is 5. A very common cause of loss of cooling in the fresh food side is the vent are blocked for cool air exchange from the freezer. Find the two vents to and from the freezer to fresh food side and make sure they are not blocked. Most problems can be solved by decluttering freezer and fresh food side.
Next check to see if the evaporator fan is running. This fan provides the push for air circulation through the vent dampers in this type of refrigerator.
If this does not fix the problem and is still under warranty, call the 800 number and pay the small service fee and get a professional to analyze and determine which part is not working.
Hope this helps.
Dec 15, 2014 | Samsung RS265TDRS Side by Side...
Our 2 door stainless ken more refrigerator is not cooling but the freezer is working good. Thanks for your help
Your evaporator fan is probably not running. Another thing to check is your freezer port to fresh food side. If you freezer is blocking the air flow your fresh food side will not cool. Find the vent to fresh food side and see if you have air flow, if no air flow you need a new evaporator fan.
Sep 26, 2014 | Kenmore Refrigerators
What else can I check - my fresh food side of fridge is still too warm, freezer fine.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
Jul 21, 2014 | GE Refrigerators
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Psc25mstass the evaporator is frosted up in the fresh food section. What keeps the evap. coils defrosted and or what makes them frost up? The fresh food section is not cooling>
heatman101
Aug 25, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
Jul 28, 2009 | Refrigerators
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
