Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer does'nt spin water out of clothes - Kenmore 3.2 cu. ft. Plus Top Load Washer
  • Anonymous Mar 18, 2009
    washer agitates but stops after "wash" cycle
  • plazavieja Apr 17, 2009
    installed new drive coupler but still doesnt spin
  • Kenmore Master
  • 3,361 Answers
If it drains the water out, replace the direct drive coupling.
Posted on Mar 11, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
My washer will nt spin fast enough to drain all water out of cloths.
There's a good chance that the clothes are not spinning very fast BECAUSE they are too wet and heavy. The root of that problem is probably a blocked filter. I would suggest you check and clean your filter (Probably behind a door like the fuel flap on your car, situated in the bottom of the machine chassis).
Feb 02, 2010 | Kenmore Washing Machines
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washer does"nt do last spin
Often people think machine not performing "last spin cycle" when machine "pausing" allowing gravity to drain wet clothes then turn clothes again then pausing again allowing gravity to drain wet clothes. Wait for a minute or two verifying machine in normal "pause" status.
Apr 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
116 people viewed this question
Sal De
fordexpert
Robert Rankin
