Question about Kenmore Refrigerators
Freezer fan will not run
The freezer fan will not run, the compresser runs and cools down but the freezer fan doesn't run to circi\ulate the cool air
  • Kenmore Master
  • 3,361 Answers
Replace the freezer fan motor.
Posted on Mar 11, 2009
  • Lennie Core Nov 09, 2012
    I have the same problem with my GSS25SGMDBS. I have replaced the freezer fan and mother board. How can I test the freezer fan motor? What voltages and where do they come from ? Wire colors ? What else could it be?
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have a small Roper Top Freezer refrigerator. Twice the freezer coils iced up and I had to defrost them. Each time the freezer came back to a low temp (in the teens to zero) but the refrigerator will not...
Hello James; It sounds like you have a couple of problems. One with the defrost circuit which is made up of the defrost heater, defrost thermostat and the defrost timer. Since it is a Roper it could be any of these items. You can check the heater and thermostat with a multimeter and if you have no resistance on on the heater it is good, the thermostat will have a very low resistance (28 ohms is normal), and it both are good then it is the timer. Now for the main problem, since you say the fan is operational and the cooling tubes are open then I would suggest you run a wire (14 gauge or guitar string) down the drain on the refrigerator side and clear the blockage. I know this doesn't make much sense, but although the fan is pushing air out of the freezer into the refrigerator section (at least somewhat) it has to have air ciculation so either your drain is blocked or the lower cooling tube is blocked preventing a complete circulation path. BTW if you have had cooling tube blockages in the past you can use a strand of wire (14 gauge) hooked over the defrost heater and down the top cooling tube to keep frost from building up.
Sep 26, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Fan in freezer runs and is cold. No air is coming
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Refrigerators Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
