Question about HP Deskjet F340 All-In-One Printer
Will not print
It ran out of paper during a project then it would not start up again, it has paper , ink etc. it will not take any commands
    Problem Solver:
  • 15 Answers
Hi have you tried this hold the cancel button 4 a few secons then press the start copy color button it should start a test page, if all fails u can uninstall it and reinstall it, i do this atleast once every 2 months its a pain.
Posted on Mar 11, 2009
My printer is printing way to dark and using too much inc. can it be reduced
Yes it can. Toe save INC. you have to set the printer settings to FAST print. If you use special printing commands such as Poster, Premium, BEST, Photo paper, or as such, you put the demand on ink at the highest ratio. If you set the command to plain paper, fast printing, standard paper type, etc. then the printing heads use less ink or INC.
Feb 09, 2018 | PRINTER Office Equipment & Supplies
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
After cleaning printer heads no ink is printed
If its an EPSON yes! There may be other brands that do it as well You needed to mention the brand and model which did not appear in the question
Aug 17, 2009 | Office Equipment & Supplies
Will not print.. cannon pixma ip3000
Ink has dried in the printhead. You need a new one, QY6-0064-000, around $50.00
Jun 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer do not print any file
I usually face the following problem while giving printing command to my printer:\r\n
1. On clicking print from file meno the printer does not print and the yellow light upwards starts blinking.
2. Reinstalled the printer after inserted the Printer Software *C6464-10018* v 41 *MacOS 8.1*USB
but printing did not start from this even.
3. sometimes earlier I experienced that only 2-3 lines get printed and after that the upper yellow light again started blinking.
4.Some times the printer goes on sucking papers and prints as the signs of playing cards or some other abnormal shapes lining etc.
Please be kind enough to solve my all such problem and if possible point out step by step action to be taken by me during such an eventuality at a later stage also.
regards: rcsharda44@yahoo.in
Jun 12, 2009 | HP DeskJet 640c InkJet Printer
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Faulty Ink Cartridge?
You can try this, but maybe a new print head is needed.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon i475 InkJet Printer
Won't print
I've been helping someone with a similar problem on a Deskjet (but it might be a different model and connected via a print server (on his router).). Did you reboot the printer or just the computer? Also did you close all of the printer sections after searching for the paper jam? In my experience the continued flashing lights indicate the document is still in the queue. The solution I've found for other Deskjets is to unplug the USB cable from both the printer and computer (or print server) and wait five minutes. Plug in the USB cables and go back to the computer. For Microsoft Windows OS (2000 and up), in the command prompt window, type "net stop spooler" <enter> without the quotes. When the command prompt returns, type "net start spooler" <enter> (again lose the quotes). Alternately you can use the Run command and type "Net Stop Spooler" <enter> (again without the quotes), reboot the computer, then wait a while.
These directions were adapted from Tutor-tips http://www.computer-2tr.com/tips/05/20050815.html
May 31, 2008 | HP DeskJet 825c InkJet Printer
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
