Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
I need a printable Wiring Manual for carrier 40 kmq 01824 do you know where I can get one? Thnak You
    Scholar:
  • 144 Answers
I hope this helps. http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/40km-1si~2.pdf
Don't forget to give me a Fixya rating
Posted on Mar 11, 2009
Honda schematics
printable? all that is seen on your screen , is printable. for sure.
the car has like 100 pages on topic.
buy the FSM , or use alldata dot come.
or tell what part you are working and we can post 1 page.
wiring of what, the car has Very complex wiring, endless.. really...
if you look in the book, its HUGE.
lighting
drive line, huge.
brakes ABS.
transmission, controls.
Audio.
other options, cruise, lots.
automatic inside dimming mirror, OMG, really>?
charging
starting
buy the fsm
if in usa , buckup $15 for alldata.com and look, and download it and print it, like us.
Jul 18, 2014 | Honda Accord Cars & Trucks
Fix zeiss 5015
Sounds like it is trying to boot from the disk?
If you have a floppy disk in the drive take it out and restart
If still not wiorking it probably needs a new floppy drive.
Jul 19, 2013 | Optics
I have a 96 camaro and I need to replace my carrier bearing. Where can I find one?
I am not sure your car has a carrier bearing, but if it did it would be located on the drive shaft between the transmission and rear end of the car.
Apr 22, 2013 | 1996 Chevrolet Camaro
My carrier bearing is bad in my 96 firebird and I can't find another anywhere. No one has heard of a 2 part driveshaft in my car. Can I replace it with a solid driveshaft? Or do you know where I can find a...
If you mean the carrier bearing on the driveshaft - then you must have a v6 model. I would advise to skip replacing it and instead purchase a 1pc shaft (no carrier bearing). The cb is located near a Hi-Speed CV Joint which make changing the carrier a little difficult.
A new replacement 1pc driveshaft costs about $225.00
The carrier bearing itself may run $40-$140. ( http://www.fortwayneclutch.com/index.php/driveshaft-parts/carrier-support-bearings/gm/1993-2002-chevy-camaro-v6-pontiac-firebird-v6-carrier-bearing-new-f-body-carrier-bearing-for-v6-models-pn-s-3r80-40.html ) - for reference...
You could also check a junk yard for a 1pc oem shaft (most shafts there are bent or have bad uj's and will cost $$ to have fixed )
>1994-2002 f-body models all have the same length from the seal of the transmission to the center of the uj @ the diff.
>when looking for an oem 1pc shaft you will find them in Steel and Aluminum. Slight differences in length when measuring center to center of the universal joints ( 40 7/8" - 40 1/2" ) - but the slip yokes vary in length, weighted / non-weighted..etc = this will make it appear the the shafts are different.
>>watch out for oem shafts with the weighted slip yoke from manual 6spd v8 models. This slip yoke may hit the trans/exhaust mount that is used on v6 models.!!
Jul 22, 2012 | Cars & Trucks
Model#41085
You may download a copy of the manual/recipe book here. It's a printable PDF file so you should be able to print it on your printer. It's 40 pages.
May 06, 2012 | West Bend Kitchen Appliances - Others
Need a wiring diagram for 81 xs 400
here is the full repair manual in PDF, and is printable. costly, but is a must have product......
http://www.tradebit.com/filedetail.php/9330080-yamaha-xs400-full-service-repair-manual-download
Jan 06, 2011 | 1981 Yamaha XS 400 Special
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER i need to know how to program the remote control.
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Feb 09, 2010 | Carrier BCA101R Air Conditioner
I need a printable diagram for replacing an altenater on a 1994 ford mini-van. Does anyone know a website to find one for free?
Removal
  1. Disconnect battery ground cable (14301) .
  1. Remove snow/ice shield.
  1. Remove engine air cleaner intake tube (9A624) .
  1. Disconnect the generator voltage regulator wiring (14305) to the voltage regulator.
  1. Remove wiring connector bracket.
  1. Loosen the drive belt tensioner (6B209) and remove the drive belt .
  1. Remove the bolts holding the voltage regulator to the generator bracket (10A313) .
  1. Remove the voltage regulator from the generator bracket .
Installation
  1. Position the voltage regulator on the generator bracket .
  1. Install the bolts and tighten to 40-55 Nm (30-40 ft-lb).
  1. Install the drive belt over the generator pulley .
  1. Adjust the drive belt tensioner as outlined in Section 03-05 .
  1. Connect generator voltage regulator wiring to the voltage regulator. Tighten generator Battery Positive Voltage (B+) wire attaching nut to 9-12 Nm (6.5-9 ft-lb).
  1. Install wiring connector bracket.
  1. Install engine air cleaner intake tube .
  1. Install snow/ice shield. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more for powertrain control module to relearn the strategy.
  1. Connect battery ground cable .
Jul 28, 2009 | Ford Aerostar Cars & Trucks
Printable manual & guide
Hello susanbalgua
I was able to find one for you ,after a bit of looking about !
It's in printable adobe PDF format like you wanted :)
I hope you like it , & find what you need
Download The Singer 1120 English manual PDF HERE !!!!
Jul 16, 2008 | Singer 1120 Mechanical Sewing Machine
Nikon D-40 SLR DIGITAL CAMERA
You can download it here.
If you choose the printable download, you have to login and specify your camera serial number.
If you just want to read something, or want to download it to your computer, you can use the non-printable version.
May 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
100 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
