I need to know the steps to change a starter on a 1994 jeep wrangler
Is it the straight six? if so first disconnect the battery then there should be 2 bolt 13 or 14 mm. take wires off. then reverse for install.
Remove bolts that attach starter to bellhousing. remove any brackets on nose or body of starter that attach to the block (if any) Remove wires on solenoid. Reverse to install. Before starting work, remove battery cable from battery. If your radio has an antitheft code make sure you know it before doing anything.
