Unable to record show on the DVR
I cannot record a show on the DVR whether it's in the future or running and I want to record. When I hit the red record button, if I have the show on the menu, it highlights but when I hit record and get the screen for picking the record this program it acts like it's going to record but when the time comes for the dvr to record nothing happens. It has been working up until about 2 weeks ago when we tried to record a show.
  • 71 Answers
Try a hard reboot. Hold the power button on the box till it turns itself off. It will turn itself back on. After restarting try to record live tv. If you can't watch recorded shows either your harddrive may be fried. After thought, a $20 tv tuner card from e-bay for your computer, you could record them to your desktop.
Posted on Mar 15, 2009
How do I record future programs using duel mode on tv2
To whom it may concern,
When you set an event to record you will be prompted as to whether or not you'd like it to record on tuner one or two. Simply select tuner two.
Best of luck
Dish guy
Feb 24, 2015 | DISH Network Televison & Video
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
Cm7000pal dvr stuck in wizard on continue in searching for channels seams to load on hdd then goes to continue
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the Loading Channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed that twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jan 22, 2014 | Channel Master CM7000PAL HD DVR
Reboots then shuts down again
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened "on the hour" just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
Oct 07, 2013 | Channel Master CM7000PAL HD DVR
Unable to access recorded on dvr
Check to see whether the laptop has the driver for the dvr. Right click My computer --> manage--> device manager---> check whether the device is displayed.
Or
The cd/dvd is corrupted and cant be read.
Apr 12, 2013 | Medion MD 96340 Laptop
Channel master cm7000pal
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jun 29, 2012 | Channel Master CM7000PAL HD DVR
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
How do i choose tv1 or tv2 on my DVR?
Your recording will record onto your one DVR box, for playback on either tv. On many satelite boxes you have to search for the program you want by entering the name. Then select the program and select to record the future broadcast.
Dec 07, 2008 | DISH Network DVR-625 DTV Receiver /...
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
547 people viewed this question
Top Televison & Video Experts
