Question about Xerox Office Equipment & Supplies
Recently got a second hand xerox document centre 432st, can hook it to our ethernet LAN with DHCP configuration and able to make it act as network printer, but cannot make the scan to file feature work to make it scan to XPs and Vistas within the network. Do anyone knows how to configure it to scanning and save to a PC in network ? Thanks
    President:
  • 2,072 Answers
You need a scan to PC kit that has to be added to the machine.
Posted on Mar 11, 2009
Good day. Hoping to get some startup advice. I need to access a new newly reset Nortel 470 switch to configure
you need to reset the setting before you can get the access to the device. Hard reset should be good. once done, plugin to your existing LAN, discover the IP taken via DHCP. configure the device.
Web interface should help you to do quick configuration.
Mar 25, 2015 | Nortel Networks Ethernet Switch...
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*
Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.
Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)
Second method *This only works if the tl-740 router supports AP mode (Access point).
In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
Jan 26, 2013 | D-Link DSL-G604T Wireless Router
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
IR2200 as a printer/scanner - wireless network configuration
You need to hook an ethernet cable into your network. You could get a wireless router to extend another one and connect via ethernet into that if you prefer.
For setting up network settings, do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 Canon Network ScanGear 2.21 (don't get the colour version) can be found on the Canon website (google it). Instructions for scanning are in the manual included with the download.
Jan 09, 2010 | Canon imageRUNNER 2200
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
Oct 10, 2009 | Computers & Internet
How can I connect my printer directly to the router and share it? There are 4 computer hook up to the same router, we want to share a printer through the router, the printer is not connected directly to...
Without knowing the models of your equipment I can just give you some general instructions.
First your printer needs to have an Ethernet port. If it does then you can just connect it to your router/switch with an Ethernet cable.
If you don't want to manually configure network settings on every device on you LAN then you need to turn on one (and only one) DHCP server on your LAN. This is the thing that hands out the network configuration to all your your devices on the LAN.
Your router / switch will probably have a dhcp server built in. Find the manual for your router / switch to learn how to enable and configure it.
When you turn your printer on it should get it's network settings from the dhcp server on your switch / router automatically.
You might want to hard code the mac address for your printer on your DHCP server so your printer always gets the same IP number.
You then need to configure a connection on each of your pc's to connect to the print queue on your printer. You will be able to follow the instructions that came with your printer for this.
I know there is a lot of jargon here. There are a few concepts to learn but once you have those sorted out you can apply the same principles to many networking situations.
Just google the terms you don't understand to get a better understanding of what it means and why you need it.
Jul 09, 2009 | 2wire (1000-400108-001) Router
Want to use westell 327w as access point only
Yes, you can try to set up your network as follows:
  1. Unplug the second (Westell) router from anything and power it on.
  2. Reset your second router. Press and hold the Reset button on the router for 10-30 seconds. This will return the router to its factory settings and avoid any complications from the set-up you might have had when the router was being used as a primary router
  3. Connect one computer to the router. Do not connect the second router to the first at this time!
  4. Configure the second router at http://192.168.1.1/ (Check you manual for details. Usually the username is "admin" and the password is either blank or "password".)
  5. Change the LAN IP address of the second router from 192.168.1.1 to a free address within your LAN (see what IP range is used by your first router! If it using the same range (192.168.1.xxx) then 192.168.1.2 should be O.K.). The address you change to (192.168.1.2) must not be used by any other device with a static IP address in your network nor should be assigned by the DHCP server your network. A default Linksys router uses 192.168.1.1 itself and the DHCP server assigns 192.168.1.100-149.
  6. Turn off the DHCP server on the second router. (This is important, otherwise you end up with IP conflicts!)
  7. Save your settings.
  8. Unplug the computer from the second router.
  9. Connect an Ethernet cable from a numbered LAN port of the first router to a numbered LAN port of the second router. Do not use the Internet/WAN port on the second router!
  10. Start up the first router if necessary and reboot the second one as well.
  11. Voila!
The only problem I can see here is that your first router - now in charge of security - does not see your wireless clients as wireless, because they connect via an Ethernet port. Because the second router is connected via a LAN port, it is not using the router functions (DHCP, security, etc.) That might be ok with you - I'm just pointing it out.
If this doesn't work for you, just come back here, leave a comment and we take it from there.
Good luck and thanks for rating!
Apr 02, 2009 | Westell Wirespeed VersaLink...
Fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Aug 02, 2008 | Xerox WorkCentre M123 Copier
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like 192.168.0.1 and a subnet mask like 255.255.255.0. That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like 192.168.0.100 to 192.168.0.199. If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case 192.168.0.2 to 192.168.0.99 are available. You need to assign one of those like 192.168.0.2 to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like 192.168.0.20. You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router2.gif options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
133 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
