Question about Dell Dimension™ B110 PC Desktop
Processor I have an old dell dimension b110 and i cannot get the heatsink of of the processor to upgrade it. If you know how to do it please help me!
    Sergeant:
  • 219 Answers
Your computer uses a Intel Pentium 4 processor, just make sure when you buy a new heatsink or processor fan that it fits the pentium 4.
Let me know if you need more information.
Posted on Mar 11, 2009
  • 2,229 Answers
First, what kind of upgrade do you expect to do? Many motherboards will not accept a different processor. That being said, you can use a small flat tipped screwdriver between the heat sink and processor. There isn't much room, but very gentle prying all around should do it. You may heat it up a bit with a blow dryer to soften the heat sink compound that hardens with age. You can't harm it with the temperature of the air from a hair dryer.
I WANT TO UPGRADE MY DELL INSPIRON ONE 2305 PROCESSOR
As long as the new one works in the same socket type then just take off the heatsink pull out the old processor, put the new one, put new thermo paste on the new proc and attach the heatsink. You can get the paste at radioshack. Only put a dime sized drop on the cpu.
Sep 18, 2012 | Dell Inspiron One 2305 Desktop Computer...
You have to put a lot of weight on the heat sync for it to boot up
I would assume that it's the cpu heatsink? Actually, it's a bad thing to put extra weight on the heatsink for it may damage the processor. The spring and locking mechanism of the heatsink is just enough to transfer the heat from the processor to the heatsink. Problem maybe on your processor not properly seated on the slot. Remove the heatsink assembly, and release or remove the processor from the slot. Check if there's a foreign object in the slot, a brush will do the cleaning. Reinstall the processor and the heatsink assembly.
Sep 06, 2010 | Dell Dimension 4700 PC Desktop
I have a dell dimension 4600i. I want to upgrade
It should.. Here is a link to documentation.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/specs.htm
Apr 28, 2010 | Dell Dimension 4600 PC Desktop
I upgraded my B110 to 2x1GB of ddr400 ram. (PC3200) It is running at 333MHZ instead of 400 and my processor is bogged down. (Like 99%)
you will need to adjust the RAM setting in the BIOS, BUT you will need a manual to tell you how.link below. Also I have no doubt you have but ensure,again, it is the correct RAM.
support.dell.com/support/edocs/systems/dimb110/
Feb 24, 2010 | Dell Dimension™ B110 PC Desktop
Best motherboard that will fit the case of my Dell 8200 PC. I want more ram and maybe upgrade the processor.
The best MB for that chassis that will fit without any Modification is a Dimension 8400/PWS370 Dell Motherboard. The chassis power button/USB connection is a proprietary Dell connector and using any 3rd party MB will require modification and the wiring is almost impossible to find for that control board.
For just about the same cost (MB, Processor, Heatsink/Fan and RAM) you can buy a New Vostro 220 with a Core 2 Duo processor w/3GB RAM and a 320 GB HDD and it is under warranty
Dec 30, 2009 | Dell Dimension 8200 PC Desktop
How do i remove the processor on a dell optiplex gx 280 from the heatsink and repaste the processor seems to be like glued to the heatsink?
The heatsink compound does act as a weak glue over time. To remove the heatsink, twist gently after removing the clamps, to release the junction. The CPU should stay in it's socket. Scrape off the old compound and add new and re-install the heatsink.
Sep 23, 2009 | Dell Pentium IV 2.8GHZ Processor Unit...
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Replacing the processor on Dimension 3000
Here is a link to the Dell field service manual. I find that these drawings are usually good enough to get me going.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1043338
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension™ B110 PC Desktop Logo
105 people viewed this question
Alun Cox
