Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
New filter but water dispenser still not working
Kenmore side by side indoor water dispenser
I knew the filter (located inside the refrigerator) was due for a change but one day it completely stopped flowing. Thinking it was the filter clogged I went and got a new filter and replaced it. With the new one installed I hear the filter filling and building pressure but it never gets to the dispenser. The refrigerator was never moved. The line is completely enclosed in the back with the only visible section visible in the front at the bottom on the freezer side feeding the door and ultimately the dispenser.Do you have any ideas?Craig
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Posted on Mar 12, 2009
Water dispenser not working on Kenmore refrigerator
Is it making any noise when you press the flapper if no then change water inlet valve
Dec 17, 2014 | Kenmore Side by Side Refrigerator
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Jun 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Water dispenser dispenses particles into the water. Drained about 7 pitchers of water. Particles are smaller but still coming. Restaurant water looks better than this. What's happening and what can I do?...
first; turn the water of to the machine next, remove the water line in front of the filter using a large bowl place the loose hose into the bowl and turn the water on for a minute turn the water off and, check the bowl for particles then reattach the filter and do the same thing on the other side of the refrigerator if this water is clean the interior refrigerator filter must be checked usually it is the carbon filter inside the refrigerator that is bad you can find the drawings location and, procedure for this part at: searsparts.com
Apr 25, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water dispenser not working but ice maker works
It could be the water valve located on the back, lower left corner of the freezer. On the outside. It's fairley easy to test. Just swap your water lines around. If you get water from the door then you need a knew water valve. If not then it could be the circut board in the dispenser. You will have to slide the face off of the dispenser. Hope this helps.
Jan 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water and Icemaker do not work
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
173 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
