Question about Dryers
Kenmore Gas dryer Model# 11070202990 Will not heat but turns on and spins
  • Dryers Master
  • 8,220 Answers
The number one problema with a gas dryer is usually those intermittant solenoids mounted on the gas valve. If you have no igniton then the first thing I would look for is a blown duct fuse. Mounted on the back side of the dryer on the filter housing near the blower it looks like this:
Kenmore Gas dryer Model# 11070202990 will not heat - 52f69e9.jpgMore wisdom HERE
Posted on Mar 11, 2009
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
Kenmore gas dryer serial number 97220100 spinning and turns on but not drying or heating up
heatman101/.>?'
Aug 12, 2011 | Kenmore Dryers
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer won't heat - Kenmore model 11070202990
did you kink or turn off the gas valve? the igniters can be fragile some times and the slightest bump can break them. open the access panel in the front and see if you have a red glow if not then check it for power
Dec 11, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 73501 Model No. 11097350100
it could be your gas dryer ignitor, flame sensor or gas valve..do you smell gas? can you see the ignitor glow? if you can answer these questions I can help. Thanks
Sep 05, 2007 | Kenmore 73052 Gas Dryer
Dryers Logo
249 people viewed this question
Top Dryers Experts
