Question about Freud FT2000E 3 Router
Where can i get a new switch for the 2000e?
Believe mine went out when i tried to start with the lock on.
  • 2,176 Answers
OK the switch I found that you need is part number 76325.7001 and to find it I would suggest going to Freudtools.com and they have a dealer locator on the home page, if you have trouble give me your location with zip code and I will find one for you. Good luck
Posted on Mar 18, 2009
Why won't my key turn the ignition for my 2000 Dodge Stratus. The steering wheel is not locked but neither key will turn in the ignition.
Probably aftermarket alarm. Should be a small switch close to it to turn it off. If it were mine, I would remove the system .
Nov 28, 2015 | 2000 Dodge Stratus
Wont start
it seems that the lock is stuck or broke. Try to see if u can move it by hand. if not u may need to remove the switch while doing this make sure the wires were connected and not loose. your ? does not say the type of washer u have. mine is a whirlpool deut and I took off kick panel on front bottom of washer and was able to reach the switch when I replaced mine. u can get a new switch at applianceparts.com
Apr 10, 2014 | Washing Machines
I,AM LOOKING FOR A POWER SWITCH FOR MY 2000E PLUNGE ROUTER
You can order your switch from Freud at (800) 334-4107. It is number 42 on the parts breakdown which you access at: http://www.freudtools.com/images/manuals/FT2000VCE.pdf
Freud's part number is 76325.7001
It doesn't seem like anyone stocks Freud parts. Went to some discussion sites and found that even repair centers don't stock them. You'll have to contact them directly.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Freud FT2000E 3 Router
I drove the car alot that day and then I went to start the car and it wouldn't start. After it had sat for a couple hours. It cranks but will not start.
I have the same problem with mine,I found out lately that this car is designed for anti theft lock so always lock your door when you park even if you're just refueling. try switch it ON wait for 10 minutes until the security lock stops blinking, turn it off then start.
Oct 28, 2010 | 2001 Oldsmobile Alero
Driver's side power window will not go up or down. I believe that the switch is no longer working. How do you swap out the switch?
Common problem for 2000-2005 Impalas. Mine went bad a year or so ago. Available on Ebay. Go new, not used. Or you can do what I did. Get a new one as back-up, took mine out, cleaned the contacts, put it back together, and resold my new one.
Anyway. There are two screws in the pull pocket rear of the switch. Remove screws and lift the rear end of the cover and unhook the front. Unplug the window and mirror plugs. The switch can be unclipped from the cover.
Aug 24, 2010 | 2002 Chevrolet Impala
Alarm
Mine has done this and i as well do not have a working remote. To disengage it just put the key in the driver door lock and turn for 2-3 seconds and it will disengage. i didn't even know mine had an alarm until coming out of work one night and it went off and i could not get it to turn off unless i went to "unlock" the door and hold it there for a few seconds.
Apr 14, 2009 | 1999 Dodge Durango
Reversing switch on 2000e gearbox
it is located on the side of the gearbox either on the rear extension housing or in the middle main gearbox housing it should have 2 wires comming out of it
Apr 12, 2009 | Ford Escort Cars & Trucks
Minn Kota 80lb 24V Trolling Motor
I had the same problem and found the oring/seal had let water into the motor. I believe it overheats or draws too many amps when wet? New seals fixed mine but I had to replace the bearing because it had been doing this for a while and the bearing had rusted out.
Jun 08, 2008 | GPS
Memory card locked
I had the same problem and it took me forever to figure it out! On my memory card there is a tiny slider that slides up and down. Mine was slid to "lock" I just slid it back and it was no longer locked! Sounds simple enough now that you know, huh?
Aug 23, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Freud FT2000E 3 Router Logo
256 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
