Question about Compaq Presario 3045US Notebook
Not detecting hard drive
So he put an external hard drive and checked the bios and it also was not detected
  • 1 more comment
  • David Koss
    David Koss Mar 11, 2009
    What do you have to do to find out to check the auto-matic detection?  Can't get into xp.  He did go into the bios and was able to click on the option to test the hard drive and it passed.  but still can't get into xp.
  • David Koss
    The think is Cajun is that he don't have a cd that came with it for xp home edition.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    was it set to automatic detection
  • 741 Answers
Its good that BIOS is seeing the hard drive. The auto-detect is an option in BIOS but since you can see the hard drive you don't need to use it..here are the instructions on how to fix the Master Boot Record, this is what boots you into Windows..good luck and let me know if you have any questions.
http://support.microsoft.com/kb/307654/
Don't forget to rate this solution.
Posted on Mar 11, 2009
  • Randall  Trahan
    Randall Trahan Mar 11, 2009
    well you are out of options, there is no other answer..can't do anything else, go to TigerDirect.com or NewEgg.com or even amazon.com and see if you can get a good deal on a XP disc, Its not going to be the last time you'll need it..or borrow one from someone you only need it to do one fix, the Recovery Console/Fixmbr to fix your sector.
  • 2,229 Answers
Need to know what operating system you are using. Win XP should see the external (I'm assuming it's a USB drive). Are you sure the USB port is working? Try another.
You may have to right-click on My Computer, and choose Manage from the menu. Go to disk management to see if the computer sees the device (probably Disk 1 for you). You may have to enable it.
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
Wont boot up says no hard drive detected
Check the BIOS to see if the hard disk is detected,if not open the case and re-seat the data cable on the hard drive and alsowhere it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Dec 15, 2010 | Dell Latitude D620 Notebook
I tried to format my Dell laptop but it display internal hard drive not found
Go to the BIOS configuration and see it the BIOS detects the hard drive. If it doesn,t detect the hard drive then the hard drive coulf be faulty.
Another way to check the hard drive. Remove the hard drive and connect it to an USB hard drive adapter and then connect this to a computer's USB port. If this computer does not detect it as and external storage device, then the hard drive is faulty.
To get your laptop operational again, insertl a new hard drive and install Windows on this hard drive, together with the laptop's device drivers and your programs.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
Windows did'nt find any hard drive
Sep 21, 2010 | Computers & Internet
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
Bios not find hard disk
May 24, 2009 | Acer TravelMate 2303LCi Notebook
My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
May 13, 2009 | Acer Extensa 4620 Notebook
Samsung SP8022N / Hanaro 2
ok.
ok you said that you have hanaro 2 and you want to sasve something to that drive.
this is what you got to do set your hard drive as slave. ok
Jan 26, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Compaq Presario 3045US Notebook Logo
204 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
