Question about Logitech Harmony 785 LCD Remote Control
How do i open logitech 785 remote?
I found 4 screws under battery cover and have started to separate the cover but something is holding it at the top. Help
  • Anonymous Apr 03, 2009
  • Anonymous May 21, 2009
    I have the same problem
    Do you find any solution mattwarren74's ?
After forcing my open, I found two screws more. Located at each side of the "activity" button - hidden beneath a the class covering the lcd-panel and framing keys. It is attached with double-sided tape. Rip it of - and your remote will look much better than mine...
Posted on Mar 07, 2010
  • RAM1414 Feb 24, 2013
    Thanks mcroars for posting that most helpful tip.
Akai ewi 4000s neck strap mount
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Apr 22, 2013 | Akai Ewi4000s Electronic Wind Instrument
How to remove Canon A570is broken battery door
I had the same problem and found nothing online to fix it so based on what little I could find and some common sense I got it done fairly easily. Here's what I did...if you need more detail on any step either re-read it to see if you missed something or let me know 'cause maybe I missed something.
Standard warning - you are dealing with small screws, small parts and things that might break. If you damage your camera trying this repair - please don't blame me! <G>
1) remove batteries and memory card
2) carefully remove screws around the outside.
There are: 3 on the bottom, 1 under the plastic usb cover on the left side, 3 on the right side. Once those are out, remove the clip that holds the wrist strap and you'll find 1 more on the top of the camera under the wrist strap clip.
3) starting at the bottom of the camera, gently separate the back cover from the camera body. YOU DON'T NEED TO TOTALLY REMOVE THE COVER!
4) (note the small spring on the battery hatch - when you complete the next step that spring will come out so look at where it is, which way it is and don't lose it!) While holding the cover and camera body apart slightly, use a pair of fine needlenose pliers or possibly tweezers & slide the pin that holds the hatch in place toward the back of the camera until the spring and door come off. You don't need to totally remove the pin.
5) take your new door assembly and put it in place. the fun part is the little spring - the shorter end of it has to go through a small hole at the back of the hinge area, the longer end puts pressure against the hatch. Once the spring is in place, hold it there and slide the pin back into place (I found that just allowing the cover and body to come back together moved it into place).
6) try the hatch to make sure it opens/closes freely and latches
7) put the screws back in place - note that one of them is shorter than all the others - that one goes on the top of the camera under the wrist strap clip
Hope this helps!
Please note - this is the only digital I've taken apart so I'm not likely to be able to help with other makes and models but feel free to ask!
Jun 14, 2010 | Canon PowerShot A570 IS Digital Camera
My logitech 785 backlight is always on -
if the firmware didnt fix it then it's a hardware issue. I would call their wonderful support team to get it replaced if you are still in warranty.
Mar 01, 2010 | Logitech Harmony 785 LCD Remote Control
Harmony 785 charging cradle does not charge the remote. The cradle lights up as normal. There used to be a sound when the remote was put on the cradle, but it stopped a few weeks ago. The remote shows a...
Try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact I suspect.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Feb 14, 2010 | Logitech Harmony 785 LCD Remote Control
I cant open the mouse to get to the battery.
Hi
Please see the link it has a excellent guide
http://www.vk2k.com/Logitech-MX1000-Battery/
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | Logitech MX1000 Laser Cordless...
/EASYZAPPER/NEW/PROC LOGIN/START.ASP,LINE 133
You will need to completely exit out of the Harmony software and re-launch it. To do this:
1. Quit the Harmony software
2. For Windows base PC's, right click on the Harmony icon from the system tray and click on Exit
3. For Mac, quit the software by clicking on Logitech Harmony Remote Software menu at the top of the screen and then clicking on Quit 4. Logitech Harmony Remote Software
5. Open the Harmony Remote Software
You should now be able to login.
Dec 25, 2009 | Logitech Harmony 785 LCD Remote Control
A garmin nuvi 200 was given to me but the battery dies out very fast..within 5 minutes after fully charged. I found an replacement battery on Amazon, but I can figure out how to open the GPS to replace the...
On the back of the unit under the model/serial # tag there are 2 screws, if you press your finger along the tag you can fill the indentations.
You will need a #5 star screw driver.
Using a plastic tool (I use a plastic cake knife) or you can buy a proper opening tool, carefully begin sliding it along the seam starting at the card slot. Keep in mind that the back cover overlaps the front cover. The front cover has small buttons every so often to secure it closed so a little pressure is needed, don't pry. Be gentle around the switch.
There are 2 wires that you need to unplug after it is separated, With the back up, open it slightly and use tweezers and unplug the speaker terminal, don't pull on the wire. To get to the battery wire you need to remove 4 screws that hold the circuit board to the back cover. Just remember the LCD connection ribbon wire is very fragile and Static can damage the board so always touch yourself to ground before working inside. good luck.
Nov 18, 2009 | Garmin 12CX GPS Receiver
Non functioning "zero" button on Logitech Harmony 880 Rf remote
The problem may be either a stuck "0" button, or the contact on the control board is dirty. You can take the remote apart by removing the screws and slowly separating the top and bottom halves of the remote. There should be 2 screws on the back of the remote (1 is hidden under the battery/cover). If you need further assistance let me know.
Oct 31, 2009 | Logitech Harmony 880 LCD Remote Control
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
My logitech harmony 890's creen stopped working
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
if this does not work, please try.
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
if this doesnt work, i suggest that you e-mail logitech from their website to get further assistance.
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
please make sure that you tell them you have tried a firmware update.
Feb 22, 2009 | Logitech Harmony 890 Universal Remote
Logitech Harmony 785 LCD Remote Control Logo
1,880 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
