Question about Kenwood KDC-MP235 CD Player
Shuts of when radio volume is above 24
I installed this radio in my boat and I am having problems with it cutting out on me when I have the volume up to 24 and when the bass comes from the music the radio, screen, and sound cuts out with no err messages! I have checked the voltage to the radio and it never goes below 12v, thus it having a new battery and the engine running it still happens. I am pretty experianced when it comes to installing car audio and have checked the wiring numurous times to make sure the connections are correct and they are. I even replaced the speakers with new (2 6.5" JBL)! I think the outputs or the built in amp is bad in the radio itself but I want a suggestion or another solution I can do to try and fix this. I installed it after the warranty expired...
Red ignition wire is coming from a switch
Yellow battery wire is direct to battery
Black is neg wire direct to battery
Front channel is pos and neg to the two 6.5 wired to left and right
  • jefbreakey Mar 11, 2009
    I checked the ohms and that is correct to. It was doing this with the old speakers too!
Look at page 8 in the user manual. I was having the same problem where the head unit was not producing enough sound out of my speakers so I had to turn up the volume 30+ and it would cut out... Turned to volume offset to the highest possible (+8) on the source that I was using which was aux... now the volume level is blaring in the low to mid 20's
Posted on Jul 10, 2010
Check to make sure the ohms rating on the speakers is correct. should be equal to or higher on speakers compared to receiver.
Posted on Mar 11, 2009
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
1994 Cadillac Fleetwood Radio. Once turned on the display cuts out, you can tune the radio to a station. The problem i'm having is that the radio will go from low volume to very high and then cut off...
Most likely, you will have to remove the radio
& take it to a car radio shop
Not many around anymore
They usually resolder whatever & put a
new belt on your Cassette or CD Drive & your good to go
Aug 03, 2011 | 1994 Cadillac Fleetwood
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
Boat stereo shuts off when turning up the volume
When any radio shuts off wth high volume it is caused by several things.
1. The maximum power output was reached and the unit goes into the self protection mode.
2. The most common reason.... The power transistor has partially failed and will not provide the partially amplfied output necessary.
3. Units with removable face plates vibrate enough to disengage the face plate contacts so the unit shuts off.
4. The speakers are too big for the radio causing it to self protect. (system mis-match)
5. Loose connectors/pins on the radio input and output connections.
6. A poor system ground that is good enough for low volume use but when high power use is encountered the ground is not good enough to carry the amperage necessary.
These are the most comon reasons for a unit to shut off at higher volumes.
It is not always an easy fix troubleshooting this problem. I know first hand as a life long electrician that has the exact same problem with the radio in my automobile. (Mine appears to be a power transistor grounding problem) With shipping to the repair center each way and the flat rate repair cost it would cost as much as a new one!
Thanks for using FixYa.
Kelly
May 12, 2010 | Boating
Milwaukee Jobsite Radio 49-24-0200 Ser.-414c Volume Fades
the volume control needs to be cleaned. if you can carefully take the back off, the volume control may have some small openings in the housing. spray contact cleaner (or even a small amount of wd40) in it and work the control back and forth and see if that does it
Aug 09, 2009 | GE Superadio III AM/FM
Volume issues with clarion M309 installed on a boat
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
Jul 02, 2009 | Clarion M475 CD Player
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Sony CDX CA720X in my boat
Mac, I had the same problem, it was the hard wired remote at the Stern. When I unplugged it from the radio, everything came back to life and the radio and CD player are working fine. I'll have to replace the other remote at some point.
Hope this works for you...
Brian
Jul 16, 2008 | Sony CDX-CA720X CD Player
Kenwood KDC-MP235 CD Player Logo
236 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
