Question about Apple iPod touch
My ipod is disabled and says to put it in itunes
How do i fix it
  • Anonymous Mar 11, 2009
    i restored and now it says plug into itunes and itunes say newtwork problem
Iv gt d same problem i dont knw wht 2do ...do u knw?
Posted on Mar 11, 2009
  • 13433 Answers
SOURCE: my ipod touch is disable and when i connect it to
1. disconnect the usb cable from the touch, but leave the other end of the cable connected to your computers usb port
2. power off the touch, (press and hold the sleep/wake button for a few seconds untill the red slider appears, then slide the slider. Wait for the touch to turn off.
3. press and hold the home button while reconnecting the usb cable to the touch. When you connect the cable to the touch it should then power on.
4. continue holding the home button while the touch starts up you will see the apple logo
5. when you see connect to itunes, on the screen you can release the home button and itunes will display the recovery mode message.
when you do that correctly, then you can restore the touch.
Disabled and code problems will be reset / removed.
Posted on Jul 13, 2009
  • 13433 Answers
SOURCE: My ipod touch is disabled and when I try to
Hey,
Follow the instructions on this page exactly to get it unlocked.
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Thanks and good luck.
Ekse
Posted on Apr 26, 2009
dalegough
  • 12 Answers
SOURCE: My iPod Touch is disabled/"Powned" and I have no clue how to fix
plug in you i pod then hold down the power buten for 3 secons then with out reliseing the power buton hold down the home for ten seonds then let go of the power button and keep hold of the home button for 30 seconds then in itunes it should say unresponsive ipod or sumet like that when this hpens click RESTORE this will restore your ipod to its factory settings....
then just sinc ur stuff back on and there you go
hope this helps
dale gough
Posted on Aug 11, 2009
anujtaluka
  • 392 Answers
SOURCE: ipod disabled won't connect to itunes
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
But you will lose all your data
Posted on Sep 21, 2009
  • 81 Answers
SOURCE: the ipod id disabled and it says connect to itunes
http://www.fixya.com/support/r4302594-unlock_locked_ipod_touch_without
follow this
Posted on Mar 09, 2010
I pod is disabled
1. Manual reset by Home key + Down Volume key, this can fix many general iPod problems.
2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library.
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question. 4. Take the iPod to Apple store, the technical support will help you fix the problem.
Nov 29, 2013 | Apple iPod Touch 4 Metallic Zebra Hard...
My ipod is disabled and i need a simple way to fix it!! It says that connect to itunes
iPod Is Disabled After a series of more failed attempts, your iPod displays the same "iPod is Disabled" message, but with an added "Connect to iTunes" message. At this point, your iPod shuts down completely and you cannot make any more attempts to enter the passcode. In order to restore the device at this stage, you need to connect it to a computer with iTunes installed. Ideally, connect it to a computer that you've used before for syncing your iPod.
Sep 03, 2012 | Apple Ipod Touch 32gb 4th Generation -...
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
Please HELPPP MMEE with my ipod touch PLEASEEE
Here I have the easiest solution for you but this will cause a permanent loose of all the data you have on your ipod.
If it is okay with you then follow my instructions here
Dec 19, 2009 | Apple iPod touch
My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
My ipod touch is disabled because i tried my
put it into dfu and restore it. youll lose everything but youll still get on it. just google how to get into dfu i think its like hold power button 10 seconds home button with power button 3 seconds and home button for 30 seconds. then itunes should say that it found an ipod in restore mode or something.
Nov 30, 2009 | Apple iPod touch
How do i fix it.
Hi
Ekse
Feb 23, 2009 | Apple iPod touch
My 8GB ipod touch is disabled and showing connect to itunes
Hopefully the option wasnt selected to delete the ipod after a certain number of incorrect passcode entries.
When you connect your ipod to itunes its going to reformat it.
(meaning it gets erased, they do it as a precaution)
DONT FORGET THE CODE NEXT TIME!
Jan 04, 2009 | Apple iPod touch
Ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
Jun 28, 2008 | Apple iPod touch
Apple iPod touch Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
