Question about Philips Televison & Video
Phillip magnavox 32 inch lcd no picture blue screen
Magnavox 32 inch lcd model number 32mf23id/37 have sound no picture just blue screen
3 Suggested Answers
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
SOURCE: 37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
Unplug and replug it...it should work eventually.
I have the same problem with my 32".
But it eventually goes on when i try it a couple of times (the number of times is completely random...sometimes none, and sometimes like, 3).
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: Magnavox model 32MF23ID/37 42
Just use a core from a old comouter it is the same thing
Posted on Aug 24, 2009
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
Magnavox 32mf23id/37
The video you inserted here shows nothing but a blank screen. Its back-light inverter board should be checked. There is no back-light now. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Apr 28, 2013 | Televison & Video
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 05, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
Magnavox 42 inch flat panel cannot get a picture
TV may need software upgrade. Go to menu, find instalation, find software upgrade, find. If version is bellow FL2D-r23 (#23) TV needs upgrade.
Get upgrade on the internet onto a USB flash drive. The file may be a ZIP file, if so, unzip to a folder in PC then put the file to the USB drive.
Turn TV on, plug in the USB drive, wait til the upgrade is finished. Unplug USB drive, turn TV off w/remote.
The TV will then turn on by its self and the upgrade is complete.
Hope this works
Sep 27, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox model 32MF23ID/37 42" LCD TV need a power cord
Fox International is Philips' parts distributor. Please call 800-321-6993 to order the power cord you need.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 29, 2009 | Philips Magnavox 42MF521D/37 Television
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
