Question about Yamaha XS-350 2-Channel Amplifier
I have a yamaha amplifier in here for repairs, the model no is A500, i cannot get the speaker protect relay to come on, i have replaced all the transistors & capacitors in the speaker protet circuit to no avail, i,ve checked the outputs from the amp & all is ok, i,ve even replaced the relay, can u help
  • peter857 Apr 14, 2009
    Hi Chaps, just came across this site and yes, I have a Yamaha A-500 (great Amp) with the same problem. Except the relay clicks in then clicks out after a few seconds. Just got a cct download and about to do some surgery after testing the DC offset at the output. Seems the speaker protection cct looks at the LH channel only? Any ideas what's wrong Dan?
  • 4,234 Answers
Measure DC to ground on the output transistors to check for any offset. The protect circuit is the least likely to be the problem. Post the readings here and I'll guide you from there.
Dan
Posted on Mar 11, 2009
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Yamaha RX V-795
Start with the process of elimination...disconnect speaker wires and (obviously) speakers. Does the amp still enter the protection mode? If not then check wires and speakers for issues. If the results are unchanged, look for protection circuit problems or "overlooked" power supply issues. Good luck...
Jun 01, 2014 | Yamaha Audio Players & Recorders
Auto off within two seconds Yamaha RX V795
Are speakers connected when you try powering up?
If so , you have an output imbalance where there is too much DC voltage on one of the outputs and the Protect is working OK....In my opinion , not worth getting repaired ( UNless you're a tech and can do it yourself)
May 26, 2014 | Yamaha Audio Players & Recorders
MY MHC-GNZ7D MUSIC SYSTEM ONLY SHIWING PLEASE WAIT , ITS NOT WORKING PLEASEGIVE ME SUJETION
One possibility is that the power-on speaker protection delay is stuck on. The most common cause of this is a shorted transistor in one of the power amplifier channels. In that case, you will need to replace the speaker driver transistors in that channel. I don't have service information on your particular model; it may use power amplifier modules rather than individual transistors.
The tricky part is identifying the amplifier power and speaker output terminals to test for this problem. To find a shorted output transistor, you need to measure the resistance between the output of each channel and the plus, then the minus power supply connections. There is a relay between the amplifier output and each speaker terminal on the back; this relay is turned off by the speaker protection circuit, so you can't measure from the speaker terminals. If you have a fried transistor, one of the tests will show a resistance of a fraction of an ohm. A good transistor will have a very high resistance or read open. This will be the case whether you have modular amplifiers or discrete transistors.
If you see a blown fuse, that is a strong indication that you do have a fried transistor. Sometimes the speaker protector circuit shuts down fast enough to save the fuse, but not always.
Apr 27, 2011 | Sony Audio Players & Recorders
Fails to switch on but a clicking noise is heard when power button is pressed.
Sounds like the protection relay for the speakers constantly activating,indicating either a short circuit or high bias current on the amp power supply. A qualified tech would be able to say easily with the right gear
Jan 02, 2011 | Yamaha DSP-AX1 10-Channel Amplifier
My yamaha P7000 always lights its protection lamp whenever turn on...
The amp will require service. One or more power transistors have failed and the protect circuit keeps the power supply from blowing your speakers
Oct 12, 2010 | Yamaha P-7000 2-Channel Amplifier
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
How do you switch from 8 ohms to 4 ohms on a 3500 yamaha amp
Switch what? It accepts 4 ohm speakers for stereo mode just fine.
Jan 25, 2010 | Yamaha P-3500 Amplifier
My Hifonics BX1500d is still going in protection mode... can that be fixed? greets Gerben
sorry, i am in the US. I couldnt begin to tell you where to get your amplifier repaired.
Try contacting HiFonics at www.maxxsonics.com
There are 3 possible conditions a HiFonics amplifier will go into protection -
Ground Loop - Blown or damaged speaker causing damaged Output FET.
Power Supply Failure - Blown Capacitors, Damaged FETs, Faulty Relays.
Thermal Shutdown - Excess Heat.
Mono channel amplifiers are the simplest to work on - and I would Estimate a repair cost of $75USD if it is a simple FET replacement.
Look at one hour of labor plus parts.
Hope this helped.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 28, 2009 | Hifonics BX1500D Car Audio Amplifier
Protection of yamaha pc 2002
Protect delay is in the relay and not adjustable as to delay time.
I would not worry unless no sound then may have to replace relay.
GOOD LUCK
BIG RED
Feb 20, 2008 | Yamaha P2500S Amplifier
Yamaha XS-350 2-Channel Amplifier Logo
441 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
