Question about GE Refrigerators
I have an older mongram refridgerator (42 inch). It takes 134a, and has two shrader (sp) valves. I assume that the one that goes into the compressor is the low press side. It shows min press (less than 5psi) when compressor is running. Do I charge to a certain press or to a temp or both. And with a empty system how much freon does the system use by weight?
  • john_gayle_w Mar 11, 2009
    Thanks for the answer. I bought the refridgerator used, no manuals. I have looked top, bottom ,inside, outside, front, back. Where is the model plate found? The compressor has a plate that says 11.8 lra??
    President:
  • GE Master
  • 2,651 Answers
5psi on te low side seems to be a fine pressure to be running at. asfar as how much there a model plate that shows amount of oz.
Posted on Mar 11, 2009
  • Ron Coons
    Ron Coons Mar 11, 2009
    not really sureas to where other then perhaps at top of refrig section, should , include, model number, serial number, anf few ohter important details. there also may be a tech sheet in the upper compartment. it may say so on there
I have a Acura rl 2005 and my a/c doesn't work and I want to know what's the problem.. My heat works but not the a/c.
You will proably need a diagnostic done by a professional because it takes special tools to test for refridgerant. A couple things you can look at . First with car off see if you can move center part of compressor if it spins good if not, compressor may be problem. Then remove low side shrader valve cover and depress valve quickly, does any gas come out,if so good now start car,turn on a/c does center of compressor spin or is it stopped. If not spinning may be low enough on charge that low pressure cut-out has engaged. If it spinning you may have a plugged expansion valve take it to apro
Apr 04, 2015 | 2005 Acura RL
Shrader valve on a 2001 626 Mazda
there is no shrader valve on the 626 u need to pull the plug on the top of the filter but your problem sounds like a main relay under dash
Feb 14, 2014 | 1999 Mazda 626
Kenmore dehumidifier 106
Are you sure that it takes 134a? That is the refrigerant that is in cans. Without knowing what the pressures are on the high and low side and the ambient air temp, it is hard to say what the issue is. I would check the compressor cut off and that is controlled by the thermostat. If it is not shuttting off the compressor, then the temp of the evaporator coil gets too cold.
Jan 20, 2014 | Dehumidifiers
Air suspension
Probably not. If you did the compressor would likely pump it back up again. There may be a shrader valve on the pump that you could use to drop the line pressure, and then unplug the compressor.
My guess would be a faulty height sensor.
Aug 29, 2013 | 2006 Buick Lucerne
Can i recharge compressor labeled R600a with R134a
If your seriously going to do a conversion I would atleast change the compressor to one that is designed for R-134A. The density in the two refridgerants are different and I just don't see a positive outcome by leaving the old compressor in.
Apr 27, 2012 | Refrigerators
1999 gmc Jimmy only Blows hot air. Diverter actuator is moving and working. Even when compressor starts all pipes are hot. Check 134A and was low. When put in less than a can the compressor would cycle on...
When recharging the ac you need to recover the old refridgerent. That means you have to take out all the old 134 and replace with new 134. On the engine sticker under the hood should tell you how many pounds of 134 it takes. When put in the 134 make sure your ac is on high.
Jun 30, 2010 | Cars & Trucks
Fridge freezing
Low freon charge will cause the compressor to run continuously, as it never reaches the set temperature. This will also cause excessive ice buildup as well. I am assuming this little fridge doesn't have an automatic defrost. If it does look at that next. You didn't say, but does it reach proper temperature? Go to the back where the compressor is. Feel the lines coming out of the compressor. the low pressure, or larger one, it may have insulation around it, should be cold. If you cant tell (sometimes these small compressors they look the same size) its the line leading inside the freezer. Feel about 1 foot away from the compressor, if possible. Next feel the high or small pipe, this one is going to the outside coil. This should be very warm, but not cool and not real hot. This goes for the compressor too. A 134A system sometimes is very hot when low on freon.
Jan 09, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Recharge Refrigerant 134A into Fridge
get a pericing valve from your local appliance parts store 25 inch and put it on the small little what i like to call pig tail make sure your pluged up and running when you do this .go get a can of 134a from autoparts store best one is advance autoparts get a car ac switch over kit from r12 to 134a and in it will be a fitting that will fit your pircing valve then read instructions from their .GOOD LUCK !!!!
Jan 02, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
