Question about HP Pavilion dv6000z Notebook
Laptop monitor is black
Hp pavillion 6000 seems to be functioning; but screen literally went black while using
Could hear the application still running; but monitor was dark
can monitor be fixed
  • HP Master
  • 5,568 Answers
The fastest way to eliminate the video section of your PC is to use the VGA port with an external monitor. If you can get any kind of video, then the problem is narrowed down to either the fluorescent backlight itself or the inverter that supplies it with high voltage; neither of these have any influence on the video output to an external monitor. The LCD section itself can't really fail at once since it is made up of tiny pixels and while it isn't uncommon for indivdual ones to fail, the likelihood that all fail is very remote.
The problem is; without some technical skills, it would be tough to pin it down to one of these two. The backlight tube is a specially formed fluroescent and if it appears to be blackened at either or both ends, then the tube is dead. If it appears pristine, then the inverter is dead; this is normally a small board apart from the main board and not too bad to replace.
Accessing the backlight is of varying degrees of difficulty and if it isn't done carefully, you could damage the LCD portion.
If it seems to boot OK, if you peer at the screen from several shallow angles, you should be able to see some 'ghost' activity on the screen.
Posted on Mar 11, 2009
Power up computer...hear the windows jingle but the screen is grey
Try connecting an external monitor and see if that gives you video - if that works, your laptop screen may have gone bad and need replacing. If it does not work, check that you are not running in too dark a screen or the wrong mode. I dont know specifically which HP key code changes this but there should be pictures on your "F" keys to indicate this. Remember to push down the"Fn" key at the same time.
Jul 29, 2014 | HEWLETT-PACKARD Computers & Internet
No display on laptop screen and external monitor to perform any action on hp PAVILION DV9700
use some special function key combination you activate it for output vedio device such key combication start fn key + function key to display output
May 19, 2012 | HP Computers & Internet
Ihave an hp pavillion laptop where the screen went black and need a solution to fix
First hook a spare monitor to the video output jack usually on the back, if picture comes up! it indicates a bad inverter board, or the backlight has stopped working, if the spare shows the same problem, it means the video graphics card is defective and normally built into the motherboard.
Mar 05, 2012 | HP Computers & Internet
Can you help me, my laptop is hp pavillion tx 1110ca. the problem is when i turne it on the monitor display nothing all is black, what shall i do?
Are you hearing any beeps when you turn it on, or does it seem that the computer is starting normally but with no picture? If you have another external monitor, try plugging it in using a VGA cable from the laptop to the monitor. If it works, it indicates that the laptop screen or inverter require replacing, if not, the Graphics chip may have died.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | HEWLETT-PACKARD PAVILION TX1110CA LAPTOP...
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
Toshiba laptop satelite a135-s2386. I went to turn on computer and there is power but the screen is black. Thanks!
connect an external monitor on the unit and press the key combination to get the video on an  external monitor this is different on some laptops on HP dv 6000 for example it is FN F4 if external monitor work the problem is with your laptop display if the external monitor doesn't work its probebly your systemboard als check your memory.
May 04, 2009 | Computers & Internet
HP Pavillion 9925nr LCP monitor turns black
Check screen brightness.
On keyboard is normally activated by combined FN + Fx keys (F9 or F10).
Check your keytops and/or your user manual.
Using this feature you should be able to restore a standard contrast on your screen.
If it isn't working the only alternative is external monitor.
Feb 16, 2009 | HP Pavilion dv9000z Notebook
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion dv6000z Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
