Question about Honda Garden
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
  • 30 Answers
It's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
Posted on Mar 11, 2009
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
If there is black oil coming from the bottom of the pump area there is a good chance it is either coming from the pump or the engine. If the oil is coming through the pump one of the seals is bad.
Unlike most brands the Black Max offers very limited parts for their pumps and depending on what model you have there is a good possibility that the oil seals aren't available. On the other hand, you should be able to find a pump to replace the one that you have at a very good price.
If I knew the model number of your machine I could better assist you in finding the correct replacement pump for your machine.
Oct 20, 2010 | Honda Black Max 2600 PSI Pressure Washer
What type of oil can i use
The engine and the pump can use the same oil. SAE 30 non detergent oil. No need to pay more for speciality oil. Check oil often and look for any unusual signs such as milky or foamy oil in pump which would indicate water leaking past seals. Good luck.
Sep 04, 2010 | Honda Black Max 3000 Psi Pressure Washer
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
Honda 2500 pressure washer,
The oil in the front of the washer turned a cream it has water in it. Any comments?
Apr 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
1,252 people viewed this question
Top Honda Garden Experts
John Trevino
Are you a Honda Garden Expert? Answer questions, earn points and help others
