Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
We bought a new GE bottom freezer refridgator Sat 03/07/09 today the ice maker is not making ice and the temp is not getting cold enough in the freezer or the refridgator. We have truned the temp down but it isnt helping. Thank You
  • bpnlp Mar 11, 2009
    It was fine saturday, Sunday and Monday. We had Ice all weekend.
  • steve
    steve May 11, 2010
    Did you hook the ice maker to a water line and turn it on?
  • 163 Answers
If not getting down to temp. it wont make ice.your ref. should be working by now.you need to call where you bought it and they will have some one come out.
Posted on Mar 11, 2009
Ice maker makes very little to no ice.
If the freezer temp isn't cold enough it won't make ice if you can check temp it should be close to 0deg f. . if you don't have a temp guage us you ice cream hard it probably cold enough. The frigidaire ice makers fail often
Oct 19, 2015 | Frigidaire Refrigerators
HAVE GE PSS26MSRSS SIDE BY SIDE THAT WILL NOT FREEZE COLD ENOUGH OR MAKE ICE
Hi , you probably need a repairman to check the freon level and test the thermostat
Jun 19, 2015 | GE Refrigerators
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
Ice maker not making ice
Hello, mine was not working and I called out a service tech they said I had a leak in the sealed system and I needed a new evaporator and freon. It was not getting cold enough to make ice, should be 0-10 on temp control to freeze. Good Luck, Tammy
May 21, 2012 | GE Monogram ZICS360NRRH C... Bottom...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
New used refrigerator
HI thanks for your question. a fridge takes at least 24 hrs to get cold and cycle give it some time. the gurgling is normal its the freon boiling in the freezer. its normal. thanks the appliance doc. please rate my answer. thanks.
Jun 19, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerator doesnt sem to be working right
Ice maker will not work if temp in freezer is not cold enough to keep activated
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting
Oct 08, 2007 | GE Profile PSI23NCR Side by Side...
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
719 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
