Question about Roper RS22AQXKQ Side by Side Refrigerator
I have a roper MOD rs25agxnq02 and it is leaking from under it. I looked under it and discovered that there is a pan that is full of water. How do I remove the pan and why is it full of water?
Leaking underneath how do i empty pan
Posted on Apr 14, 2009
    President:
  • Roper Master
  • 2,651 Answers
Its normal for there to be some wate rin the pan, it should evaporate itself out. the fact that thesis so much, perhaps yo can flash a light under and look for wate rleaking into it.or perahps theres a crack in the pan allowing water to fall through
Posted on Mar 10, 2009
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Roper RS22CFXTQ00 side by side. It leaks water in the floor. Water gathers under bottom drawer in freezer then leaks into the floor. I also have a problem with the hose that feeds water to the...
first check for a hole that water should drain tru. it must drain under the ref. into a pan and then it is evaporated by the heat.. u need to go on the back of ref.,. look where water goes into the freezer and that will need to put some putty or soke tape to stop the air leak that is causing your spout to freeze.. try those. ok
Feb 11, 2011 | Roper Refrigerators
Water is dripping from the freezer down to the fridge. My vegetable and fruit bens are constantly full of water.
Hello lay.... that water is supposed to make it's way through a small hole in the floor of the fridge and down to the evaporator pan just above the floor. Begin by getting a flashlight and then remove the lower grill below the door of the fridge. Look under there with the flashlight to see if the evaporator pan is dirty. If so clean it. Then remove the bins at the bottom of the fridge and find that drain hole. Clean the hole with a cotton swab. Joe
Thanks for choosing Fixya!
Jan 30, 2011 | Roper Refrigerators
Roper Washer is leaking at the base, It appears to be coming from the water pump.
Its not uncommon for these drain pumps to leak fortunately the are very easy to replace. Place a small pan under pump remove both hoses and then pop off the retaining clips and pull the pump forward. line up the new pumps drive slot with the drive shaft coming off the motor reinstall retaining clips and hoses Good Luck
Nov 14, 2010 | Roper RAS8445KQ Top Load Washer
Another refrigerator with same problem
Pull the refrigerator away from the wall.
Inspect the drain line and drain pan.
The drain line comes down the back of the box and into the drain pan on top of the compressor.
The drain line may have a crack in it or may be missing the pan.
The drain pan may have a hole in it.
Jan 26, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a mr.freeze sa-12863 that is leaking water under the machine.help
If the water is actually coming from under the ice maker, I can't help you.
However, I just discovered water leaking from around the top of the lid on mine. I took the lid off [by first removing both side panels and then the screws for the top] and discovered that there is a metal plate under the water spout that causes water to splash up around the lid. In mine, this led to water running out aall the way around the lid, down the sides, and all over the counter. You can't remove the spout without messing up the water level sensor, but I bent the plate a bit flatter and no longer have splashing water everywhere.
Aug 21, 2009 | Freezers
Water leaking from bottom of refrigerator
THE WATER IN THE PAN IS FOR THE FAN WHICH COOL THE COMPRESSOR. MAKE SURE THE FAN IS WORKING. IT USES THE MOISTURE FROM THAT WATER TO COOL YOUR COMPRESSOR.
BOYNISMO@YAHOO.COM
Aug 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Roper stopped working
Your defrost timer is bad. The defrost timer motor probably quit in defrost mode, thus no power to the compresser
Mar 30, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
211 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
