Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Print spooler service not running
I am running Windows XP and have a HP Officejet Pro L7580 All-in-One. I get a message "print spooler service not running". What do I need to do to correct this problem?
  • 2,229 Answers
It helps to know why the service is not running, but to answer your question, you need to go to the control panel, then click on administrative tools. There's an icon that says services. Click on that and when it opens, click on the standard tab at the bottom of the window. Now look for Print Spooler (they're alphabetical). It should say it's automatic and it's started. If it doesn't, right click on it and choose start.
If the service does not start, then you have another problem which will have to be addressed.
That will do the job unless there are other issues on the system. In that case, I would do a system restore back to when the printer was working.
Posted on Mar 11, 2009
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
My HP officejet 6110 only prints in black and white
Every time I try to print I get a message saying that The Spooler service is not running, what should I do?
Feb 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Print preview shows up blank and blue!!??
it seems that graphic card drivers gone bad... check it
Oct 22, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Says out of paper when i print, but there is paper there, but if i copy it copies fine, it "sees" the paper for copying but not when i am printing.
We need to remove the USB cable from the printer, navigate to Services and restart the Print Spooler service and refresh the Printers folder. Turn Off and turn ON the printer. Connect the USB cable to the printer and we would be now able to Print frmo computer.
Jun 23, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer problem
hi,
please try the following...
> click on "start-->control panel--> printers and faxes"
> right click on the printer icon, delete the pending documents
> make it online
> close all the windows
> click on "start-->run", type services.msc
> double click on print spooler, click on stop and then click on start
> restart your computer
> thats it
thanks and regards
agnel
Mar 16, 2008 | Office Equipment & Supplies
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
