Question about Nintendo Super Mario for 64
Super mario 64
How do u get 120 stars
  • Colleen Reford-Weeks
    Colleen Reford-Weeks May 01, 2009
    Is there a way to get all 120 stars through a cheat code with the Super mario 64 on the nintendo 64? My 4 year old deleted my file :(
  • 139 Answers
2 Suggested Answers
actionreplay
  • 73 Answers
SOURCE: super mario 64 ds
need ar
Posted on Aug 25, 2009
Tip
You did not like the star screws, ah? Well, how about the so-called 'security'...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Jul 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can't read star wars disks, all others work, this is the 2nd set that has failed. Pioneer BDP-120
maybe the copy of your star wars is not original disc.maybe is pirate dics.try buy new one star wars disk.rongxin
Mar 11, 2010 | Pioneer BDP-120 Blu-Ray Player
Should I be using the 2x lens or the 1.5x lens for looking at stars, also what is the correct setup of the different lens?
No matter how much magnification you use stars are always just points of light. You cannot resolve a star into a disk.
Your scope will work better at lower powers. I probably would NEVER use either the 2x lens. The maximum magnification of any telescope is about 50 times aperture. You scope is about 2-3 inches so your max is about 120 power under PERFECT sky conditions.
Read the TIPS on my profile page.
Feb 07, 2010 | Bushnell Voyager 78-9945 Telescope
Have a hayward c-750 star clear filter. Why would sand be coming through one of the jets when we initially turn it on.
Hole in the filter cartridge or if it only happens after you clean the cartridge could just be heavy dirt falling into the pipeing when you pull the cartridge for cleaning. There is a drain plug on your filter base that you can pull to clean out the bottom of the tank and avoide this.
Oct 03, 2009 | Hayward Star Clear Plus 120 sq.ft....
I have a MTPAXR 8/120 PUMP THAT IS seized and I
The best tool for this job is a gearpuller -- there are many types -- get one which matches your problem.
May 08, 2009 | Comet BXD2527 Pressure Washer Pump
Does ant one know any cheats for super Mario galaxy specifically the one where you can turn into Yoshi???thnx for the wii
I have this book "Cheat Code Explosion" and the following cheats it has is:
  1. PLAY AS LUIGI- Collect all 120 and fight bowser. After the Credits you hear Super Luigi Galaxy said by Liugi(Note to self: Luigi's running speed increases, spinning in water decreases air amount, Luigi does save Luigi in the first course of haunted house galaxy, and your cosmic twin seems unbeatable)
  2. GRAND FINAL GALAXY- collect all 120 stars with Luigi and beat Bowser. It is located on the planet with the trial galaxey. Go on the other side there is a new Green luna. In that Galaxy collect all 100 puple coins to get the 121st star. Talk to a purple Toad for a letter with a picture(varies through characters)
Apr 05, 2009 | Nintendo Wii Console
Snowboard length calculation
"Your height (inches) x 2.54 x 0.88 = Suggested Board Length Rider Height Range of Board Length 4 Feet 109cm 4'2"" 114 -120cm 4'4"" 115 - 125cm 4.6"" 118 - 135cm 4.8"" 120 - 135cm 4'10"" 125 - 140cm 5 Feet 130 - 142cm 5'2"" 135 - 145cm 5'4"" 140 - 148cm 5.6"" 145 -152cm 5'8"" 147 -155cm 5'10"" 154- 163cm 6'0"" 157-165cm 6'1"" 160-168cm 6'2""+ 159cm or greater"
Dec 01, 2008 | All Star Forum Star Women's Snowboard
Microwave door handle
First, never remove the door. You will disturb the alignment which holds in the microwaves. Generally, the door can be disassembled by removing the screws on the cavity side of the door. Once inside, then you should be able to replace the handle. Often the screws are of the torx variety...also call star.
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Nintendo Super Mario for 64 Logo
288 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
