Question about Maytag MAV9600 Top Load Washer
Loud noise on agitation and spin
I've got a 6-year old Maytag Atlantis MAV9600 top load washer. It works well, but makes a loud continuous noise during agitation and spin. It's not high pitched (like a belt on a car, for instance, that's going), but rather a medium pitch. Any suggestions on what I should be looking at? Like I said, except for the noise during spin and agitation, machine is working very well. Thanks!
  • alfred_russo Mar 11, 2009
    I checked to see if anything is stuck, but that's not the case. The washer is making noise - sort of a grinding, medium pitch sound - during agitation and spin. I don't think it is the spin bearing because the sound continues even in spin mode when I stop the tub from spinning. I took off the front of the machine, and can't tell whether the sound is coming from the transmission/seal assembly or water pump. When I raise the lid (stopping the cycle) I hear a "whooosh" as the agitation or spin stops. Otherwise, machine is working fine - no problems with washing, just very noisy.
    Any additional help in trying to diagnose the problem would be very appreciated!
  • 11,896 Answers
That noise would be the bearings that are used between the tub and motor.
Posted on Mar 11, 2009
  • 163 Answers
Could be transmission,you can see if any oil has been slung by taking front panel off.also listen to see if pump is making the noise.
  • 640 Answers
Hi,I may be able to give you somethings to check.Either the belt is worn and making the noise (even though you already stated it didnt sound like a belt).The lower bearing on the tub is worn.If you can tip it and expose the bottom of the washer you may be able to tell the difference.If you see alot of black,small specs and the belt has a shiny glaze on it i would say the belt,if not the bearing--let me know.
    Sergeant:
    Champion:
  • 435 Answers
Hi, try running it w/o any load in it. If it still makes the noise, then the problem might be with the bearing on which the tub rotates. You can try lubricating it. If it doesnt work, you may have to replace the bearing.
Good Luck :)
Posted on Mar 10, 2009
  • 10,515 Answers
This washer would fill and agitate, but started making noise during the agitation portion of the cycle. Once the cabinet was removed, I started inspecting the mechanical portion of the washer and the noise seemed to be emanating from the pump, but when I removed the pump from the motor, the noise continued. I removed the motor to get access to the gearbox and found that when I turned the shaft counter-clockwise, the agitator would function with a distinct clicking noise present. Turning the shaft in the clockwise direction was impossible since the unit was locked up and would not turn with any force. The direct-drive gearbox is a bi-directional transmission that will provide agitation movement to the center shaft when turned one way, and rotational spinning to the clutch when the input to the shaft is reversed. The fortunate thing for diagnosing mechanical problems in these washers is if you can eliminate the other components as good, replacing the gear case as a unit will usually be fix to get the machine up and running again quickly.
    President:
  • Maytag Master
  • 2,651 Answers
Possible that something is caught in oyour pump assembly, possible that perhaps event he pump itself has a bad bearing, in wehich case youd need to replace th pump.. one way to tell is if you tilt the machine back you can hear where the noise seems to be originating, yo can also removeth belt( it simply strecthes over ht pulleys, and physically look for damage to the pump, might be quite evident
  • 583 Answers
Just check if anything is jammed inside also check by putting a less amount of clothes and see if it still has a problem.
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Agitator doesn't work but spin cycle works, makes a loud noise when in wash cycle but agitator is not working
This means that the transmission has failed, check the use and care guide some had a ten year warranty.
Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV9600 Top Load Washer Logo
313 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
