Question about RIM Blackberry Curve 8300
Broken BB 8300 Usb connector . Part number details plse. Got it apart and trying to find replacement part. I am a retired tech so I have a solder ****** and small iron
  • 173 Answers
Try ebay and use searchwords "blackberry 8310 USB port". It should pull out 3-4 sites that sell them. The $6 ones are the same as the $19!!! No difference. However be very carefull removing and resoldering the part. If you damage one od the ports on the main board, you have damaged your phone permanently and need to use a external charger from then on....
Posted on Mar 11, 2009
Broken usb conection in verbatium hd
if you are mechanically inclined and have a soldering outfit you can probably just re solder the connections, and or find a replacement USB connector if it is broken and replace it
Apr 05, 2012 | Verbatim 97397 Store N Go Super Speed Usb...
My blackberry 7105t won't switch on even battery is ok. i even tried charging it with different charger and connecting it to pc yet nothing happen--blank screen & led light not lit.
Hi there. It sounds like the USB connector has broken off the phones motherboard. You can order a replacement part from www.cnn.cn and replace it yourself. You're looking for the USB charging port. If you're not comfortable taking apart the phone and soldering, your best bet is a new phone. Alex
Jun 30, 2011 | Cell Phones
Will not charge
Are you using the AC Adapter, or USB sync cable to computer to charge? If using your computer to charge, you will need to have USB Driver for your BlackBerry Model installed. Download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5It
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your Battery http://www.amazon.com/Blackberry-External-Battery-Charger-8300/dp/B002YGYLA8/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263514496&sr=8-2
Dec 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
How can I replace a bad (unuseable) USB port in a computer
More than likey the pins on the usb port have become loose.
You would need to take apart the laptop and either
A. re solder the pins
B. Replace the USB port
C. The motherboard is bad
Guide to disassemble your laptop
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
To solder you will need a soldering iron (perferably one with an adjustable wattage 40Watts should be good and some .2mm solder works good for computers since its very fine and easierto solder small contact points
Once the computer is apart locate the USB port and flip the motherboard over and there should be 4 pins, you should be able to wiggle them if they are loose
Apply solder to loose pin to secure it or form a big glob of solder on it and use a solder pump to pull off all the old solder and re solder, this is the preferred method because it ensure the entire pin is surrounded by new solder
For a Novice this will probably take around 3 hours
Nov 02, 2009 | HP Pavilion dv6000z Notebook
The prongs on the USB connector broke off. Do we need to replace a board and if so how do we do so?
You can buy new connector and replace broken one. You need skill at soldering and of course have to open the unit to access the broken connector.
Oct 10, 2009 | M-Audio M Audio Keystation 88es 88 Key USB...
How do i transfer music from pc to bb curve 8300?
You can't put songs that you have bought from apple. You can put songs that you have riped from CD's or downloaded. You need a micro SD card. On the phone go into options: Advance Options, Media Card. Turn mass storage mode on. Now plug your BB into the computer and a little window will open up. open the Blackberry folder then music. Drop and drag your music files into that folder. if your going to use the Desktop software go to google and type: Blackberry Desktop Manager 4.5. This version comes with a media manager. http://crackberry.com/blackberry-desktop-manager-version-4-5-now-available Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | RIM Blackberry Curve 8300
The usb connector on my 500 gb seagate mseries is broken however i noticed that i can remove a plate on the bottom and replace the part my question is where can i get this part
There are 2 other solutions to this problem.
First way is to find someone that has the other module P/N 100452909 Dual FireWire 400 and use FireWire instead.
Second is to pry open the USB module and have the USB connector re-soldered or replaced. The connector is similar to many of the smart phones, so a cell phone repair shop could probably replace it. Heck you might even have the connector replaced with the newer Micro USB connector or ask them to solder the USB wire direct to the interface board.
Jan 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Change Mic on BB 8310
Sadly I would send it to a repair shop. Since it is soldered to you mainboard you run the risk of actually damaging the phone if you attempt to remove it.
Jan 16, 2009 | AT&T Blackberry Curve 8300 Smartphone
Power adapter for Magellan 700 is broken
Connector J1 is the power connector. The left post corresponds to the center lug. The middle post is the outer connection. The right post closest to the USB connection is just an anchor - no connection.
Jan 04, 2009 | Magellan RoadMate 700 GPS Receiver
RIM Blackberry Curve 8300 Logo
424 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
