Question about Hotpoint NVL333EY Electric Dryer
Hot point model nvl333eyoww will ot dry clothes
I took out the drum and checked heating element. It all turns red. Once you start the dryer in turns few for a few seconds and then goes out it will come back on but just for a few more seconds. I removed the wires from the high limit thermostat and it turns red and stays red. I replaced the high limit thermostat and it still does the same thing. What else could the problem be??
  • 686 Answers
Your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Posted on Mar 12, 2009
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Taking 2 to 3 hours to dry a load of clothes...checked dryer vent from dryer to outside and it is not clogged.. what can the problem be?
Are the clothes hot when you take them out? If not, then maybe your heating element is broken. Easy to replace that, just pick one up from a parts store.
Our dryer started to take a long time to dry clothes but the heating element was working. We opened it up to check for lint and so on, and it turned out that the drum had slipped slightly out of location and the back of the dryer was partially obstructing the duct. That was probably what was making the dryer squeak, too. We reseated the drum easily in a few seconds and now it dries well again.
Feb 18, 2011 | Dryers
Mayteg model DE313 clothes dryer that stopped drying clothes.
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Jul 21, 2009 | Dryers
Runs and heats but will not dry
Fist need to know if it is gas or electric dryer, it makes a difference.
If an electric dryer, It is possible that one of the heating elements has failed (burned out), which would still allow the other one to get hot, but not enough to completely dry the clothes during the normal timed or automatic drying cycles.
You can check this with an ohm/amp meter if you are comfortable with working around 220V-AC voltage, etc. You'll need to remove either the rear cover, (if your unit has rear access) or the top of the dryer and then the drum, to gain access to the electric drying elements. This depends on which model you have and how old a dryer it is, etc.
Once you've done that, you can sometimes see a broken drying element, if not, you can check for continuity with the ohm meter (make sure the power cord is unplugged!).
If you are unable to determine with this method, you can restore power and briefly put the dryer into a timed dry cycle (drum and drive belt removed, while you visually check for heating elements turning red/orange as they heat up. Only do that long enough to confirm which element is good, be very careful, as they get extremenly hot. Once you know which one is bad you can order your replacement by model number , etc. Hope that helps.
Jul 13, 2009 | Maytag Dryers
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer quit after about 20 minutes-see more details below
do you have clothes on top of dryer? if so, i'll say it again never ever stack clothes or anything on top of it. Things on it insulate it and will overheat the machine. Yes it has a overheat linit switch but to get to it you have to take it apart and pull the drum out depending on the style of heat element you have. Some are in the back of drum and others are in a tube on the floor of the unit inside. If yours is behind the drum then drum needs to come out to check for the problem
Feb 26, 2009 | Amana Dryers
FEX831CSO dryer stopped heating mid-cycle
Apr 22, 2010 My dryer would not dry the clothes either. the heating element would only come on once then nothing. The high limit thermostat was bad. Pull the electrical plug. Remove the top cover and the thermostat has an orange/black wire to it. It is hard to get to the screws but I was able. Then I found the element would cycle many times but not stay on long enough to dry the clothes thoroughly - I found the culprit - the motor driven fan creats a suctionin the drum and the hot air from the rear coil is pulled thru the drum, thru the front door (via the holes in the door's inner face) down thru the lint screen, thru the outer fan housing and out the exhaust. My problem was that the door's cardboard backing had seperated and along with the trapped lint clogged the door's holes and restricted the air flow. I took the door off, seperated the 2 halves, removed the cardboard and cleaned the lint out. The dryer is now working like new. Summary: The high limit thermostat was bad probably from cycling so much and the air flow diminished slowly over time to the point I did not notice until the clothes just wouldn't dry. Check the air flow first. Hope this helps
See less
Dec 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Sep 27, 2008 | Hotpoint NVL333EY Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
162 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
