Question about Panasonic AG-1330 VHS VCR
Panasonic AG-DV2000P internal settings
Panasonic AG-DV2000P: What are the correct switch settings for DIP switch S-4 on the mechanism circuit board? The service manual does not mention them. There are 6 switches on S-4.
  • 221 Answers
Section 5 (electrical adjustments) of the service manual covers the settings of DIP switch S-4. It is used to calibrate the supply and takeup photo sensors.
Posted on May 22, 2009
Hi - I have a panasonic ag-7330 SVHS deck. It lights up but does absolutely nothing. The Video Rec Servo light is blinking constantly. Any ideas?
It could have a timer record present that needs to be cleared. Otherwise it could be the mode switch playing up. But that too can be caused by physical damage inside the unit, thus setting the mechanism in the wrong position. In other words it thinks it is in record mode when it's not!
Aug 24, 2015 | Panasonic AG-7330 S-VHS VTR PAL w/...
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
When i insert a tape into Panasonic AG-DV2700 Mini dv Playerecorder. It closes normally and then it puts the tape back out staight away Thanks Maurice
Dear FixYa customer,
There can be several reasons for the tape spitting back out including, a defective tape, foreign object/lablel in the cassette compartment, unit in timer recording with tab knocked out on tape and then actual mechanical and electrical faults.
I will concentrate on the mechanical and electrical faults here, since you can verify the others.
Electrical, would include the Power supply, and Micro processor circuits.
A weakened power supply due to deterioration of the filter components will kick the tape out if the power supply voltage drops below a certain value. The filter components deteriorate with age and heat, and then put out less voltage.
There are critical timing circuits, and sensors that control the mechanism positioning and send signals to the Micro processor. The tape in sensor, mode switch, and LED are common faults here.
Mechanical faults include the Cassette Loading Assembly, Capstan, and Drum motor. A fault in the casseette housing assembly that won't allow it to load 100%, a Drum or Capstan motor that is sluggish or frozen will send a signal to he CPU to kick the tape back out.
The Power Supply is a common failure.
An experienced technician can verify the power supply voltages and replace the filter components for approximately $25.00 plus labor.
Thank you for using FixYa
May 13, 2010 | Panasonic AG-DV2700 Mini DV VCR
If you are seeing tape collect inside the unit, the takeup side is not functioning correctly. This may be as simple as a belt change or idler change. This is not a repair I would suggest that you start with. The alignment of the tape is critical to proper functioning. I would geuss that the "link support mech" is probably just the belt/idler assembly or it is a "mode" switch. In any case, this unit should be sent in for repair. As part of that repair, the conformance to industry standards.
May 12, 2008 | Panasonic AG-DV2000 Mini DV VCR
Relace mainboard in mini dv tape deck
what symptom does it have? describe what it is/isn't doing; most of the problems I've seen with AG-DV2000s are related to either defective capacitors on the mechanism drive board or dried grease on the reel table positioning arms. I've never had to replace a main board in a 2000.
Jan 02, 2008 | Panasonic AG-DV2000 Mini DV VCR
most likely cause of this problem is loose or dirty cable connections to the video head or mechanism in the camera. get a tech to disassemble the cam and check the flex cables connecting the main board to the mechanism. same fix is good for AG-DVC10 and AG-DVC15.
Nov 14, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-1970 video out problem
there is a y/c separator in the AG-1970 which fails and produces all sorts of strange video symptoms. unfortunately, they are no longer available from Panasonic.
Nov 10, 2007 | Panasonic Televison & Video
Panasonic AG-1980
most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Sep 24, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1330 VHS VCR Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
