Question about Maytag MSD2651 HE Side by Side Refrigerator
Maytag Refridgerator and not cooling or freezing
I have a Maytag refridgerator (mod# MSD2651HEW) that is not cooling or freezing. I heard what sounded like and electical short followed by the smell of burning wires/electronics.
I checked the kitchen and outlets but everything seemed ok, the refridgerator seemed to be working. The next morning there was a puddle of water on the kitchen floor that orginated from the melting ice in my freezer.
Fans barely seem to work with a very low chill.
Any ideas?
  • edmeyer09 Mar 11, 2009
    I think that maybe the problem, the relay looks ok but you can smell the burnt wiring, I can hear some rattling when I shake it similar to the sound a borken bulb makes.
    I already called the manufacture to see if my fridge was one of the recalls, I call again to be sure about that that part.
    I appreciate the help, I will let you know the results.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Posted on Mar 11, 2009
  • Ron Coons
    Ron Coons Mar 11, 2009
    yes that s it alright, it should not rattle, the replacement may look diferent but should come with directions as to how to install
LG refridgerator that is 12 years old. Clicking sound from back of the unit t my husband heard "chiming" while he was asleep. Freezer compartment is not freezing and fridge section is not cooling.
It sounds like the compressor start relay is not able to start the compressor, but it keeps trying. Test the start relay or replace it and hope the compressor itself has not failed.
Mar 07, 2017 | LG Refrigerators
FREEZER NOT FREEZING
Hello Drdean825,
I understand that you are having a problem with your Refridgerator. The problem is that your unit is not cooling/freezing. I have a tip that you can follow that will show you how to check the mechanical side of your Maytag Refrigerator. If after you follow this tip you can not find what is wrong with the unit you can repost with make and model of your unit.
Tip for Mechanics on Refridgerator
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Maytag MTB1891ARW 18 cu. ft. Top Mount...
Refridgerator is freezing food
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Maytag MCD2257HES Side by Side...
I have a Maytag MSD2651HEW refridgerator--it's about 4 years old. Tonight I opened the freezer and I can hear and see water dropping onto the metal coil inside the freezer--so it makes a hissing sound. ...
You just happened to catch the freezer in the defrost mode... that is very normal and it should stop in a half hour or so and go back to normal operation...
heatman101
Sep 02, 2010 | Maytag MSD2651 HE Side by Side...
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Maytag refridgerator not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
844 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
