Question about NetGear DG834G Router
File sharing problem after installing Netgear DG834G ADSL/Wireles
I have a home network consisting of a Dell PC and a Dell Laptop. I was using a 2Wire wireless gateway/DSL Modem without problem and both computers could share files and access Internet w/o problem. The 2Wire died and I replaced it with a Netgear DG834Gv4 ADSL/wireless router. It installed easily and I was able to get Internet access on both PC and Laptop, but now neither computer can see or share files with the other. Any suggestions? Do I need to disable the firewall on the DG834G? (I use Norton Internet Security and its firewall on both the PC and the laptop.) Thanks for any help.
  • pwilson973 Mar 11, 2009
    I have run the setup disk that came with the DG834G several times. I have also run both the Network Setup Wizard and the Wireless Network Setup Wizard on both the PC and the Laptop several times without any success. (I ran the Network Setup Wizard first on the PC, let it create a Network Setup Disk on a floppy and used that to run the Network Setup Wizard on the laptop.) Still no improvement. Any other ideas?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Run the Windows Network Wizard in each computer on the network.
Posted on Mar 10, 2009
  • Reynaldo Valdez
    Reynaldo Valdez Mar 11, 2009
    Turn Off the Norton Firewall when running Network Wizard.
How to enable my netgear DG834G v4
By setting it up . Do you have the instruction manual this would be a good starting point. Although you did not give a lot of information I will offer you a bit of information. This router is an ADSL router so you need to have an internet service provider that can provide ADSL on your phone line. Once you have an internet service provider give them a call and ask them to guide you in how to set up ADSL and connect this dg834G router to their network. ADSL requires ADSL line filters on all phones. While you are setting up the ADSL you might want to also setup encryption on the WI FI settings security and give it a network name. in the router.
Jan 03, 2015 | NetGear Computers & Internet
Internet light on router diplayed red
The ADSL installation details have changed, so you need to update the router.
Check the router has not been moved too far from the laptop.
Jan 27, 2014 | NetGear DG834G Router
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
May 08, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Wireless connection
Did you change your wireless SSID and channel? Better to enable encryption too. If this problem never happens when you're connecting to other wireless networks you might as well update or reload the firmware/software of your router.
May 22, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Installation CD
Netgear lists these items to check.
http://kbserver.netgear.com/kb_web_files/N101234.asp
There is not really a driver needed, you just need to log into the router and adjust the appropriate settings.
See the installation and setup guides on Netgear's sight.
If you give me the link you are attempting to download, I'll help get you the file.
Jan 16, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Problems connecting to the internet with my wireless laptop
At the bottom right hand corner of your screen, you have a wireless conenction icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call netgear to verfiy what is your network key. if it is unsecure then you can log on right away.
Oct 13, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834G Router Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
