I need to find path from power to parking brake switch. I know that the color of wire is blue with yellow stripe.
    Sergeant:
  • 300 Answers
A parking brake switch for a vehicle including a switch having a contacting surface, the switch being positioned between an actuated state and a deactuated state, a first contact connected to a brake valve associated with an electro-hydraulic braking system, a second contact connected to a pair of electronic control modules, and a third contact connected to the pair of electronic control modules and a coil, the contacting surface being adapted to engage all of the contacts when the switch is in the actuated state.
tp get the exact diagram and connections check out the following link
by clicking it directly
http://www.freepatentsonline.com/6511134.html
Posted on Mar 10, 2009
  • 10,515 Answers
    Novelist:
  • 149 Answers
What is this on?
    Sergeant:
  • 320 Answers
Check out through the control module to the parking brake.
Pionner avh-x2550bt wiering diagram
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Radio wires what colors are what?
Below is the layout you requested:
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS STARTER YELLOW (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) LIGHT BLUE (-) @ HEADLIGHT SWITCH PARKING LIGHTS ( + ) PURPLE (+) or BROWN/WHITE (+) @ FUSE BOX POWER LOCK WHITE (TYPE B) @ BACK of FUSEBOX, ETACS, See NOTE *1 POWER UNLOCK LIGHT BLUE (TYPE B) @ BACK of FUSEBOX, ETACS, See NOTE *1 DOOR TRIGGER YELLOW (-) IN DRIVERS KICK PANEL or ETACS, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay TRUNK RELEASE BLUE (+), Requires Part #775 Relay IN DRIVERS KICK PANEL SLIDING POWER DOOR N/A HORN YELLOW (-) @ STEERING COLUMN HARNESS TACH WHITE (-) @ ECM, See NOTE *2 WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
Mar 24, 2011 | 2002 Kia Optima
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
Color code for panasonic model cq5301u [wiring code] i just need to know what colors are speakers wires right left front back etc.etc.and key hot and always hot wires or the color code for all the wires...
okay here it is
on all aftermarket radio they follow a color code
iginition 12 volts red
constant 12 volts yellow
ground black
remote wire amp turn on blue/white stripe
speakers
Lfront + white
Lfront - white/black stripe
Rfront +gray
Rfront _gray/black stripe
Lrear +green
Lrear -green/black stripe
Rrear + purple
Rrear - purple/black stripe
some radio have other wires too
like dimmer wire orange
power anntenna blue
and some flip screen radio have parking brake wire green
since your needing a wiring diagrame i would take it to a mecp professional 12 volt installer to install radio . about as fast as you blink your eyes you can fry the electrical system in your car and cost you 100's or 1000's of dollars buy and rewiring you car to fix it .
caraudioquestion@gmail.com
for more questions
Oct 16, 2010 | Panasonic CQ-C5301U CD Player
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
The brake light on the dash wont go off brakes are good rotors are good not the emergency brake. i have a 98 durango
check the brake fluid level and check the park brake switch it may be stuck on or out of adjustment
Apr 16, 2010 | 1998 Dodge Durango
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
114 people viewed this question
 Grubhead
Grubhead
