Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Duet front load washing machine. Model # GHW9150PW3. Water has been collecting in the bleach compartment of the pull-out drawer, after every load. I called the place where we purchased it from, but they weren't any help. They guessed that something is not draining!! Duh! Any suggestions?
  • Whirlpool Master
  • 3,361 Answers
The siphon break in the bleach compartment needs to be removed, cleaned and re-installed.
Make sure the hole underneath is not blocked.
Posted on Mar 10, 2009
WATER & SOME OF THE BLEACH DOES NOT DRAIN FROM THE BLEACH COMPARTMENT AFTER EACH WASH? HAVING TO PULL DRAWER OUT & EMPTY REMAINING BLEACH & WATER EACH TIME BEFORE NEXT USE. WHAT CAN BE DONE?
Your washer is designed to purge the bleach dispenser between loads. For example, if changing from bleach to no bleach. The residue is normal.
Apr 27, 2016 | LG WM2487H Front Load Washer
Water collecting in the bleach compartment
Thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, It is not an issue at all.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How much bleach do you add during cleaning cycle?
If the model number is correct, to run a "Clean" cycle on this model washer you need to follow these steps:
1. Make sure wash tub is empty and close the door.
2. Open the dispenser drawer and remove the plastic divider in the MAIN DETERGENT compartment.
3. Select the following options:
a. Select the POWER button.
b. Select RINSE/SPIN.
c. Select LOW SPEED SPIN.
d. Select WARM/COLD water temperature.
e. Select END OF CYCLE SIGNAL to SOFTER.
f. Press EXTRA RINSE button 4 times within 5 seconds and the
will begin.
4. The washer will run a short sensing cycle for about 3 minutes.
5. The washer will beep 4 times and a code will appear on the front panel display.
a. If "Ab" (Add Bleach) appears - skip to step 6.
b. If "Rl" (Remove Load) appears - the door will unlock and you
need to double check the wash tub for any items. Close the
door when complete and press the START button.
6. Add bleach. If this is the first time running the clean cycle add ONE CUP of bleach to the detergent compartment of the dispenser drawer. If this is a monthly routine, add only 1/3 CUP of bleach.
These instructions are listed on page 18 of your owner's manual. If you no longer have a manual, yo can obtain a FREE copy at managemylife.com. Just type in your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format that you can download or print for free.
If you have questions, please post back and let me know. I hope this helps you.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Canyou adjust the water level on a whirlpool duet front loading washing machine model ghw9150pw3?
no and if you fill by hand and attempt to start an wash cyc it should pump out the water first
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model GHW9150PW3
I cleaned my drain pump fiter (F02 ). When I put everything back together and tried a cycle, there is no water flow resulting in FH. I did not touch the water supply. Help!
Aug 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
