Question about KitchenAid KCMS185J Microwave Oven
I have a KitchenAid KCMS185JSS-2 Microwave oven. A couple of years ago, we had a power surge due to a faulty neutral wire at the pole. The oven was plugged in, but not running when the surge occurred. Ever since then, the microwave would occasionally blow the breaker. It does not happen every time that we use the oven. Sometimes it pops as soon as you push the start button, other times after it has been running for a while. My wife often uses it for the timer alone and it will run forever that way. The oven is on a dedicated 20 amp circuit with 12-3 romex. I took it into the dealer and they ''tested'' it and said that it was okay and that I should check the wiring. I pulled new cable, installed a new outlet and a new breaker all rated for 20 amps. I reinstalled the oven and it worked fine for about a week - maybe 10 uses - then it blew the breaker again. The oven is built built into a custom 27'' wall cabinet,so replacement will be a pain as the new models are a slightly different height. Any help will be appreciated. Thanks
  • 6 more comments
  • pgp_home Mar 13, 2009
    How do you test an IC without some sort of sophisticated equipment? Do I just run it until it blows the breaker then take the cover off and feel the ICs on the board to see which one is hot?
    fixe_you's response made no sense
    What do you test with a multimeter?
    Just how do you "check the control board for repairs"??
    The dealer is also one of the authorized service centers.
    I guess that I'll have to take the oven out of the cabinet, remove the cover and look inside for signs of an internal short.
    The fan runs fine. The black wire goes to the breaker, the white wire goes to the neutral bar and the ground wire goes to the ground buss. All connections at the outlet and in the service panel are tight.
    You "experts" are just a bunch of wing nuts. How do I get my money back??
    President:
  • KitchenAid Master
  • 2,651 Answers
DO NOT ACCEPT ADVICE on doit yourself site for repairing a microwave. SERIOUS INJURY AND/OR DEATH can occour, microwaves put out extreme high voltage, only factory trained techs should attemp repairs(people offeringyou advise dont even have appliance background execpt for maybe one or 2)), and yes i see youve already brought to theshop, try another shop, do not open and try to repair yourself!!!!!!!!!!!!!!!
Posted on Mar 13, 2009
    Sergeant:
  • 300 Answers
Check out the three ic which controls the circuit breaker voltage on main board .the number of ic are IC276---- IC289 -----AND THE --IC265.this all the ic controls the voltage and current flow on the main board.if they are faulty or weak they may blow the circuit breaker.also check out the door switch if that is not closing properly then also the circuit breaker blows.check out the voltage current of door switch. thanks.
  • 10,515 Answers
    Scholar:
  • 124 Answers
Hi, See if i can help.
If you have or can borrow a clip on amp meter set it to over or around 50amps & clip around wire leading to microwave. But cup of water in microwave & turn on.
Measure amp load from Amp meter. Check neutral line also should be within few 5-8 amps as main line. If your pulling 18 (80%)or more amps your going to overload breaker. Also amps should not exceed manufactured rating of microwave.
Danger be very careful around electrical wires & boxes. They have been know to injure & kill.
Hope this helped. Send comment if you need more help & I will return. Good Luck! Please Rate.
  • 2,984 Answers
With type of problem, you may have to take it in and have a professional doctor it up. Or, succumb to a new one and be rid of the problems....this could turn into a safety hazard with a lot of alterations to the unit.
    President:
  • 2,559 Answers
Check the fan and make sure it is running constantly when in use,If it stops during use,the transformer unit will go into thermal overload and trip the breaker.
Also check that the wiring is not reversed
  • Randy Hough
    Randy Hough Mar 13, 2009
    Only 3 thing cause a trip breaker,
    1. Overload,(Drawing to much amperage for the circuit)
    2. short (Dead or live)(Grounded,non grounded or improperly grounded circuit)
    3. loose connection.(At any connection in the circuit,from the bus bar to the unit connectors)
    It is either the unit is drawing too many amps or a loose connection is causing a higher draw of amperage,since a dead short would kick immediately and you said all connections are tight and the wiring is correct.
    Try the breaker in a different slot as it maybe the connection on the bus bar.
    if not,You will need an amp probe to test the draw on the unit while in use.
    Sergeant:
  • 254 Answers
A microwave oven should be used only on a properly wired 3 wire grounded
circuit. Check with a circuit tester to make sure your 3 prong outlet is
correctly wired. Many are not. Install one if it is not grounded. There
is a very important safety reason for this requirement: the return for the
high voltage is through the chassis. While unlikely, it is theoretically
possible for the entire high voltage to appear on the metal case should
certain internal connections come loose. With a properly grounded outlet,
this will at most blow a fuse. However, with the case floating, a shocking
(or worse) situation could develop - especially considering that microwave
ovens are usually situated near grounded appliances like ranges and normal
ovens and wet areas like kitchen sinks.
also check out if any wire is loose internally so if any loose and live wire internally touching the metal parets of the oven also blows the circuit breaker fuse.
  • 98 Answers
Hello i will help u.if it was my house. i would call in a repairman.And i dont would mean for your house wiring.20 amps on a dedicated line should be plenty.I think the microwave needs service. a good serviceman will be able to fix your problem.i think its the power supply.when you had that power surge. it made it a little crispy.this time call a service man or woman from your local area.not the dealer.
  • 583 Answers
The control panel board looks faulty.check the board for possible repairs or else you will have to replace the control board.
  • 1,800 Answers
Maybe an IC gets warm test anything warmer than natural and wsee if u can replace. its the one that occur the shorting out.
Posted on Mar 12, 2009
  • Jalal Sordo
    Jalal Sordo Mar 13, 2009
    take it apart
    plugg it in outlet
    when its blows the breaker test the hot area!
    the give us the part number
  • Jalal Sordo
    The Consumer Product Safety Commission warns against do-it-yourself repairs of microwave ovens. Microwave ovens use high voltage which makes it particularly hazardous for consumers to remove the cover and touch electrical parts. The possibility for electrical shock from a microwave oven still exists even after the oven is disconnected from the power source. Even unplugged ovens can cause serious injury.
  • KitchenAid Master
  • 19,396 Answers
You probably need to replace the diode or the control board.
I have a KitchenAid microwave model # KCMS185JSS. Everything works except it stopped heating up anything. Is there a separate fuse for the microwave heating? Where is it? can I fix this myself?
Sounds like the microwave's magnet tron (join two words together this page will not allow the correct word) the has gone down. They only last a short time depending on use. Not a great job to do on your own (if you do not know what you are doing) the part cost about 35pounds so most cheap microwaves are not worth repairing, if it is an expensive one it may be worth paying for the repair.
May 26, 2014 | KitchenAid KCMS185J Microwave Oven
Err F6 E8
make this test and try again. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
If the problem persist, the main control board is faulty. God bless you
Oct 27, 2013 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Microwave no power
How can you take the fuse out on this model KHMS 155LSS-4 of kitchenaid
Jan 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave partially heats
its time repair will cost more than a new one
Dec 01, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS185J Microwave Oven Logo
317 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
