Question about Whirlpool LSR6334LQ Top Load Washer
Please helpppp!! Okay, I turn my washer on and it immediately begins agitating while filling.. It seems like all other cycles work but when it gets to the end, the timer continues on to the next cycle and washes the load all over again. It doesnt stop until I push the nob in and then it will continue to make a buzzing sound as the little pointer keeps moving around. WHAT DO I DO????
  • slvrnblckatt Mar 14, 2009
    Thank you very much for the advise, Jump. Problem is solved! :)
  • Whirlpool Master
  • 3,361 Answers
Replace your timer. Internal contacts are bad.
Posted on Mar 10, 2009
  • steve
    steve Mar 14, 2009
    Good for you.
    Happy washday.
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
My GE Washing Machine fills up with water to the appropriate line and then begins the agitation cycle... The water immediately begins to drain to the point the water turns on to fill the tub again... this...
is the drain hose connected to a drain standpipe or laying in a utility tub , or a floor drain check owners manual for proper drain hose height and requirements if drain hose is lower than the height of washer it can auto siphon out of drain hose ,,,,, is the drain hose sitting in stand pipe freely or is it connected to stand pipe with no air gap
Jan 24, 2011 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 90 series doesn't spin out all the water
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
May 29, 2009 | Kenmore 22422 Top Load Washer
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool LSR6334LQ Top Load Washer Logo
174 people viewed this question
Dan Webster
Dan Webster
Sal De
