Question about Cadet Manufacturing CADET SL Series Small Room Heater Wall Heater Heater Assembly and Grill Only 120 Volts 1000 Watts (...
Won't go forward or backwards
I was mowing with my Cub Cadet Series 1000, Model LT1045 when it just stopped. The motor will run but when you press the pedal to go forward it just sits nor will it go backwards. I raised it up both back tires will move but one goes in one direction the other in the opposite direction. The wheel release that is located on the rear of the lawn mower when it is pulled out it still will not let the mower roll. What could the problem be?
Troubleshooting
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Heating & Cooling Logo
225 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
