Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Clothes smell after wash- they don't get clean. NOW WASHER LEAKS!
AND THE OIL MARKS ARE ALL OVER MY CLOTHES!!!!! I had a MayTag for years it worked great. This Tromm was nice looking, pretty color - looked high tech. Just one problem- It doesn't work!! The washer does not clean the clothes, If I use the correct soap, softner and hot water- extra hat water, still clothes smell bad. I am washing jeans, socks, tshirts, nothing really dirty or soiled - still nothing gets clean. Everything smells like the clothes have not been rinsed. Extra capacity! Extra capacity of dirty clothes. What a waste of money. The dryer tkaes fOREVER to get things dry. They are not cheap and they DON"T WORK. Oil marks, clothes are not getting clean, water leaks from under washer, any ideas????
Ask for your money back ¡¡¡¡¡¡¡
Posted on Mar 16, 2009
How do we clean with this machine .
Is this a front-load washer or top load?
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time.
If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes)
leave the door open when not in use (lets it dry out)
If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell)
Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent)
Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
Mar 15, 2012 | Washing Machines
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Apr 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
626 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
