I have a 94 honda accord when it's at about 1/4 tank of gas it shuts off i've taken it to about 5 diffrent shops including the dealership and nobody can find out whats wrong with it i had fuel filter replaced and fuel lines cleaned,fuel pump,radeator cap,fuel sending unit, if you can help please do thanks.
Sounds like the fuel supply pipe inside the fuel tank has hole that's why if the fuel level is about 1/4 and the pipe hole is not completely soak in the fuel, the fuel pump will sucks air instead of fuel and this can cause of lack of power first until the engine shut off but if your problem is sudden shut off without other symptoms like lack of power or engine rough running first before engine shutting off, most probably it was electical problem.
